Question about Home
Keeps on pumping out water from the bowl even when there is no water in the bowl
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it.
Adjust or replace a flush handle:
  1. Remove the cover from the toilet tank (the higher part at the back of the toilet). If the handle is loose, tighten the locknut with a wrench. If the nut won't budge, apply penetrating oil and let it set before removing.
  2. Unhook the chain from the trip lever and slide the trip lever, with the handle attached, through the hole in the tank.
  3. Soak the handle threads in vinegar for an hour or so to remove mineral deposits, then scrub clean with an old toothbrush.
  4. Reinstall the assembly, tighten the locknut and adjust the lift chain (see below).
Adjust the lift chain:
  1. If the handle must be held down while the toilet is flushing, the chain may be too long. Shorten it by hooking the upper end through a different trip lever, or use long-nose pliers to open and remove some chain links. Alternately, replace the chain with a new one.
  2. Some flush assemblies have a lift wire instead of a chain. If the wire binds against its guide, flushing is impaired. Loosen the guide with a screwdriver, then adjust it so that the flush valve falls freely onto its seat.
Keeps on pumping out water from the bowl even when - 059cccf2-0d34-4d81-b323-5a8ac4777084.jpg
Posted on Nov 24, 2013
Water keeps running into machine even when power is switched off
failure of the inlet valve. You can find this in the inlet pipe section, remove and check if dirt had accumulated to jam the valve. If not the valve is faulty and must be replaced.
Apr 03, 2014 | LG Washing Machines
My neighbours saniflow toilet is drivng me mad. The motor keeps whirring every 5 mins. Whats the problem, please!
Water pressure is what makes the unit kick on and off. If its kicking on by itself most likely water is somehow draining back into the pump. Start by checking the flapper in the flush valve inside the toilet tank, it may be leaking water into the bowl and from the bowl into the pump. Also inspect the check valve inside the 90 degree elbow where the waste is pump out from. The check valve may not be closing properly and is allowing waste water to drain back into the pump creating water pressure making the unit kick on and off by itself.
Oct 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Macerator keeps going off even when not flushed.
Water pressure makes the unit turn on and off. It will only activate on it's own when enough water pressure is present. Most likely it can be water leaking from the toilet tank into the bowl, and from the bowl into the pump. Or could also be that waste water is slowly draining back into the pump through the check valve on the discharge elbow, creating enough water pressure that it will make the unit kick on and off.
Aug 06, 2010 | Saniflo & Saniplus& Macerator Pump
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
Error code37 keeps coming on screen
(This is a pump out error).Water isnt leaving the machine fast enough.3 possibilities.1 The pump is jambed up completely with debris therefore no water is leaving the machine at all.2nd There is a partial blockage.3rd There is a diverter valve underneath the machine witch will divert all the water out of the drain hose OR divert all of the water over the top edge of the bowl back into the bowl.This diverter may be stuck ON causeing the the water to just be cycled forever back into the bowl,therefore the water level in the machine never gets lower.the machine is interpreting this as a slow pump out OR blockage.the diverter valve needs to be changed if this is the case.either way you will need to get the water out of the machine.
May 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Water doesnt drain,It keeps giving an error, and it makes a strange humming sound.
Hi.
Sounds like your drain pump has seized.
Ensure all water is drained from machine. This is not as easy as it sounds if full!!!
You may have to open door and bail most of it out. When this is done, pull out machine (two people needed) then tip the machine up 45 degrees. have a bowl and plenty of towels handy. Slowly open the drain pump filter, located behind the front plynth, and catch as much water as you can in a bowl. When water flow has stopped fully open the filer body and you will probably find a coin lodged in the pump impeller blades.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help!
When the backs of the rugs fall apart, they tend to bunch up in the pump and form a pasty substance that keeps the motor from turning. Since the unit knows there is more water in there than what should be, it tries do keep draining even when the unit is turned off (the buzzing noise you're hearing) The first thing you need to do is remove the lower front panel (the screws are on the botom side of it. Once you take those out the panel (with a little wiggeling) will come down then out. On the bottom of your washer, you will see a white piece of plastic. This is your pump where the remanants of your rugs have ended up. I would recommend a large bowl, towels and a wet/ dry vaccume at the ready before the next step. On the front of the pump, there is a knob whcih you turn counter clock wise to open. I recommend putting the edge of the bowl under the pump while you SLOWLY turn the knob. DO NOT OPEN IT ALL OF THE WAY INITALLY! Drain water out a little at a time. Once your bowl is full, screw the knob back in, dump the water and repeat until all of the water is out. Once the water in not flowing anymore, then open the knob fully and pull it out. You will see a white clump of the rub backing.Once you dispose of it, fill then drain your washer again. More remanants of the rug will wash into your pump. Continue this fill, drain pump clean procedure unit the trap comes out fairly clean (it will take many loads to get the last bits out from everywhere inside your washer)
Jun 17, 2008 | GE WBVH6240F Front Load Washer
Home Logo
66 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
