Question about Ovens
Technica T948SS-3 has no power
We had a blackout and the oven has not come back on, it has lost power
Chef EDC691S multifunction duo, after a power blackout the digital display for the timer flashes and upper oven will not work. Can we reset it?
The only reset is to pull the power plug for 5 min's, if that doesn't correct the problem you need a technician to come out.
Jan 24, 2017 | Ovens
Top oven works, bottom one doesn't. Have done manual operation setup 3 times, but still nothing. Any suggestions?
yes there is a thermal fuse might have blown? however not all ovens have a fuse? may have somehow tripped the oven safety valve off?
Mar 07, 2015 | Ovens
Homeking oven hof605ss
Try turning off the circuit for a minute, then set timer again.
Often a little picture/icon of a "baking tray with heat" when timer is passing power on to the thermostat.
Also, those timers fail often enough, is the oven brand new (or recent blackout)?
Oct 17, 2013 | Ovens
I just bought a maytag 24 inch double oven.it is 240 volt and i need to know if i need to put a 3 wire or 4 wire for the power
Which plug you use depends more on the outlet in your house than the oven usually. If This is a new oven with digital controls, 4 is preferable (I've seen a digital dryer blow the boards because a 3-wire lost it's ground) but if the outlet is 3, you don't have much choice but to go with 3 unless you rewire the outlet back to the fuse/breaker box. As long as it's in good condition, 3 should work fine.
Feb 14, 2011 | Maytag Ovens
After a power blackout in our neighborhood the oven display showed a blinking clock time-still keeps time- which could not be reset. The soft panel does not respond to any setting to turn on the oven in...
Try turning the breaker to that unit off and keep it off for 20 minutes or overnight, if possible, then flip the breaker back on. If it still shows the PF code, call us and we can get the correct part to you. Hope this helps.
Aug 28, 2009 | GE JTP20 Electric Single Oven
After a complete self cleaning job, the oven was not responding.
Reset the clock. if power lost at any time failsafe reset mode? see handbook! this is just a guess. cheers Mark
Aug 27, 2009 | Frigidaire 24" Built-in Single Electric...
Not heating in fan forced mode
Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
No indication on display module - apparant loss of power
Did you check the power cord.
Connection(s) could have been fried during power surge.
Dec 27, 2007 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
