Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic 53tw53 i have owned the tv of approximately 4 years, i already had the convergence problem but luckily was still under extended warranty and it was fixed. My warranty has just expired and now my tv will turn off after a couple of hours of use and wont turn on. i have to leave it off for some time and unplug it from the surge protector then it will turn on and stay on. Has anybody faced some thing similar in the past.
  • Anonymous Nov 08, 2007
    Blurred image and double image. I do not know how to resolve this problem
I had the same problem i had the amps replaced, went up in size.
Posted on Dec 17, 2007
6ya staff
SOURCE:
Convergence suddenly out of whack, colors about 4" from each other. Understand there's convergence chips for my pt53tw53g panasonic. What part no's should I use and would it be better if I had the service...
The Panasonic P/N is C5AA00000203... However, the Sanyo P/N is STK392-110, a common sub deflection puck used in many RPJ TVs. You can locate the later (without the larger price tag) on any number of retails sites for under $15 a piece. Do yourself a favor and change both in one shot.
Mar 13, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Convergence
did you check the low ohm resistors? Its not uncommon for some of them to be opend when the ICs go out.
Oct 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Problems with Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
sounds like the blue convergence IC is bad.This is quite common in all Projections units about 3 to 4 years old.
Jan 31, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence
check for loose connection by the convergence ic's
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
there is high voltage in this area be careful.
Jan 29, 2008 | Panasonic PT-53TW53 53" Rear Projection...
How to do convergence on a PT-53WX53
Hello Yann,
Please be advised that doing the convergence in service mode is a very complicated process. This could mess up your TV even more. The best TV tech out there finds doing convergence a Headache. Doing convergence is part of the repair that most TV tech fears. Email me if you still want it. I will not post here for the general public.
Best regards
Mervin Guy
Oct 15, 2007 | Panasonic PT-53WX53 53" Rear Projection...
53" Panasonic HDTV showing letters and shadow
maybe you have defective convergence correction circuit! replace a new one!
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
