Question about Panasonic PT-AE900U Multimedia Projector
The fan in my epson projector sounds like it is hitting something, can the fan be replaced
The fan first got very noisy, now it sounds like it is loose, rattling or hitting something. Can either it or it's bearing be replaced:
  • Panasonic Master
  • 10,291 Answers
Check Panasonic's website service department for the cost and availability on the replacement fan.
Posted on Jan 12, 2014
Noisy
Something is catching on the fan blades. Possibly a screw or piece of plastic has come loose and is connecting with the fan blades when you switch it on. When the projector has been cool for a few hours remove the lamp and gently shake the unit to dislodge whatever is catching on the fan.
Mar 11, 2013 | Panasonic PT-AE900U Multimedia Projector
The cooling fan stop working on my Epson EMP 700 Multimedia Projector, can I get a replacement part and replace it myself?
The temperature indicator is red.
The projector is overheating, which turns the lamp off
automatically. Let the projector cool for a few minutes,
then turn it back on. Make sure nothing is blocking the
ventilation vents.
If the projector continues to overheat after you clean the air
filter, the problem may be caused by damage to the cooling
fan or internal circuits. Contact a qualified service person.
¨ Warning: Do not attempt to service this product yourself except
as specifically explained in this User's Guide.
Representative : EPSON AMERICA, INC.
Address : 3840 Kilroy Airport Way
MS : 6-43
Long Beach, CA90806-2469
Telephone : (562) 290-5254
Jan 17, 2011 | Epson EMP 700 Multimedia Projector
The fan of dell gx280 producing a loud sound, how I fix it ?
Sometimes something is stuck in the grill and the blades keep touching it, other times the bearings have worn down and the fan or entire power supply needs replacing.  I used to hit my PCs noisy fan with the palm of my hand and the loud noise stopped!
Mar 11, 2010 | Dell OptiPlex GX280 PC Desktop
Noisy fan
sounds like there might be some ice build up around the fan housing
or something pushed the cover to hit the fan
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My bulb went out in my x1a so i replaced it now it
is the led on the top of the projector blinkng at all? if there is no led lit, the fuse on the power supply may be blown or the power supply itself needs replacing. turn the projector on. you should hear the fans and a high-pitched whir. if you don't hear that whir or it sounds like a noisy motor, the colorwheel needs replacing. if it sounds good but no light, make sure you have the correct lamp. the x1a takes the sp-lamp-009 lamp. it should have 2 white wires, each at opposite ends of the plug. if you have a lamp with a red wire and a white wire, you have a lamp for an x2. also make sure the lamp door is closed completely. if the door is closed (hitting the switch), the lamp is correct, the led is green, and the sounds are good and it still does not light, the ballast is bad and needs replacing.
Sep 23, 2009 | InFocus X1a DLP Projector
The main fan next to the projector lamp is not working and causes the unit to overheat. Is there a replacement for the fan and housing?
you'll need to find an epson authorized service center from the epson site. you can ask to buy the part itself, but they may try to talk you into sending it in for repair.
Sep 08, 2009 | Canon Epson Powerlite 730c Projector...
Noisy Motor?
Hi, It is the evaporator fan motor/blade hitting something. Remove the rear panel inside the freezer section and see what the fan blade is hitting.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 27, 2009 | LG LSC26905TT Side by Side Refrigerator
I have a Mitsubishi Multimedia Projector ( XD300U ) The fan is noisy and I am if I need to replace it. Is If so how do I remove it and where can I get a replacement part.
Open the case and check the color wheel for chips. Mine shattered and sounded like a broken fan. $+- 225 for new color wheel. Easy to replace and it worked fine.
Nov 19, 2008 | Mitsubishi XD300U Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
76 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
