Question about Canon Office Equipment & Supplies
What does load cassette paper code 1007 error on a canon mx922 mean?
It keeps on telling me i need to load paper on the cassette but it already has paper and i'm just trying to print out a paper. this has never occurred to me
  • bellarose120 Nov 24, 2015
    A4 solution WORKED!!!!!! Thanks a bunch THERIZBO:)
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
SOURCE: "paper-feed error"
Had the same problem with mine, very intermittent. Remove all the paper and open the feed tray lid so you can get access to the three grey pinch rollers. Start printing then push on the roller with your finger to try and 'rough it up' (if it clicks you are pressing too hard).
The fault appears to be that the pinch rollers are loosing their grip and can not pull the glossy paper through. I dare say using a mild washing up liquid solution would be better but this is a safe quick fix.
Did this to mine and it has worked fine ever since.
Posted on Aug 02, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
SOURCE: Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Posted on May 03, 2010
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
This problem is mainly happens to all inkjet printers. If your printer print blank pages then please at least once go to official site of Canon and check whether there is any printer/scanner drivers update is available or not. If yes then download it. Also check your ink cartridges. Because if there is no print on paper that means your ink might be dry.Sometimes it clog the print head. If your ink cartridges get dry change it. Or you should clean your printer's print nozzle by using printer's control panel. I hope all these suggestions helps you. If doesn't then watch Canon MX922 Manual English
Jan 12, 2017 | Canon Pixma MX922
Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
To fix the error:
- You select setting
- Device Settings
- Plain Paper Feed Settings
- Set up on Rear Tray instead of cassette
Oct 30, 2016 | Canon Office Equipment & Supplies
Support code 1007
Make sure you selected the correct paper tray (rear or cassette) in 'Printer properties' on 'Maintenance' page. If the correct tray is selected, try adding more paper.
Feb 24, 2015 | Canon PIXMA Wireless White Photo...
Error code 1007
Hello, Check to make sure there is no paper stuck in the printer somewhere in the paper path. It could be just a small piece as well. Also, try powering down the printer and cleaning it out with a can of air.
Dec 11, 2014 | Office Equipment & Supplies
How to fix code 6000 mx922
The 6000 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If the above procedure does not resolve the error, the unit would require service:http://www.usa.canon.com/cusa/page.action
May 03, 2014 | Canon Pixma MX922
We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
From the service manual about the paper issue this is what it says:
***Rear tray. There is no paper. Load paper and press [OK].
Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
***Cassette. There is no paper. Load paper and press [OK].
Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
Hopefully its just a setting on the printer or the computers printer properties.
Best of luck..
Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
4,166 people viewed this question
old marine
old marine
