I got this camera back in January and it was working one minute and needed new batteries. I put new batteries in it and now it wont even turn on. what is wrong with the camera??
If your batteries did not leak at all, and corrode th points where the. Batteries make contact, then it could be something very serious on the main board, or something simple like the on/off switch. Really it's the sort of problem that needs to be seen by someone. I'd check the battery connections first, then make absolutely sure the batteries are going in the right way around. Flat end is - and pointed tip end is +. Good luck
SOURCE: Batteries
This happens with almost all digital cameras. You have a couple options. first you can buy lithium batteries, which are a little more expensive but last considerably longer in digital cameras.
The second is you can buy rechargeable batteries, which in my opinion is the best option because you can reuse them, and they also last really long in digital cameras.
the problem is, you just cant really put normal batteries in digital cameras. Lame but true
I hope that my answer was of help!
