Question about Cats
Punch bowl fountain replacement - Cats
How to replace a Pentair dynamo strainer pot
I really would need a picture to be more accurate. If you have no way to hold the lid on to get suction, you have to replace the front bowl (pot) as that is where the strainer basket is and how the flow is created. That bowl (pot) unscrews from the front housing. You have to be able to free the suction pipe from the bowl and have enough room to spin the bowl off. You may also have to remove the pressure side pipe if you do not have enough room to turn the bowl (pot) off. If you can not get the bowl off of the front plate, you will have to replace the bowl and front plate all at once.
May 12, 2014 | Pentair Garden
Need a part for rival bf150 cn fountain
I need a base to my rival beverage fountain which has started to leak, I have really enjoyed it and I dont want to get rid of it because the rest of it is in good condition. BF150/25006EFADD1
Dec 10, 2013 | Nostalgia Electrics LPF-210 Punch Fountain...
I need some parts for rival beverage fountain BF250-BL
dated: Wednesday, November 20th, 2013
Call:
Rival Customer Service at 1-800-557-4825
With your model number & part number
Oct 30, 2013 | Nostalgia Electrics LPF-210 Punch Fountain...
I bought one of your fountains at a rummage sale. It had lights and 3 levels the water flowed through. I lost the cord to plug it in to the wall. All cords I tried don't have enough power to make the...
cords do not control the current
second point fixya site doesn't make fountains so you are on the wrong page
3rd point --what do you expect from a rummage sale
Oct 12, 2017 | Nostalgia Electrics LPF-210 Punch Fountain...
Have Animal Planet auto flow pet fountain. Can't get it to bubble
We had the same problem. My husband took a small black plug out of the pump hose. He said it should have been punched out of the fitting, but it wasn't. When we took it out, our pump started to work beautifully. Good luck.
Feb 23, 2013 | Discovery Channel Animal Planet Dog Or Cat...
Does the Petco Ceramic Cat water fountain need a filter?
No, most cat fountains do not need a filter to run and work perfectly fine without one.
May 14, 2012 | Cats
Water pressure too much with PEM 070
a device called a flow restrictor is needed in this case , pond supply places can source this device as it needs be sized for the size of hose your using
May 10, 2012 | Little Giant Garden
We purchased the monroe cascade solar/battery powered fountain last year but unfortunately the main bowl has not survived the harsh winter! Is it possible to purchase a replacement one?
your fountain is made in China, and their are several models of this fountain. and several manufacturers making it in China and they all just sell to an exporter that is why you can open 2 with the same part#'s and have 2 different fountains. you can try this web sight it will hook you up with the China exporter and they might be able to help you find the part....good luck
http://www.alibaba.com/showroom/solar-cascade-fountain.html
Apr 23, 2011 | Garden
Cats Logo
Top Cats Experts
Ruth summersides
Tom Chichester
RANDY POWERS
Level 1 Expert
Are you a Cat Expert? Answer questions, earn points and help others
