Question about Car Audio & Video
My pioneer deh x3500ui keeps blowing my fuse. I think the wires are connected wrong but I can't figure out what exactly.
    New Friend:
  • 52 Answers
That sounds fairly obvious and correct. Sounds like you are putting a positive wire to ground earth. You must have a wiring diagram....or perhaps you changed the plug type and recited incorrectly.
Posted on Nov 24, 2013
  • 2 more comments
  • Josh Nov 24, 2013
    Its wired to a harness u bought for an aftermarket radio
  • saranden Nov 24, 2013
    You must have a wiring diagram for either the original radio or the aftermarket radio. Each wire has a significance, ie yellow wire positive right speaker. Blue wire positive left speaker etc. that is just an example. If this helps you, I am happy. Black is generally ground on a car hifi. Except for a speaker negative, it is not a ground wire.
    There you go, someone has cleverly provided you with the recipe for success. Follow the colour codes provided and don't ground any of them which should not be! Bye
  • Josh Nov 24, 2013
    Problem solved the harness I had bought had an orange wire and I had them connected. The solution was to not wire them together
4 Suggested Answers
lostinfamily
  • 149 Answers
SOURCE: need wiring diagram for pioneer deh-p4000ub
http://akamaipix.crutchfield.com/Manuals/130/130DEHP4UB.PDF
Here is the PDF file for your radio. On page 63 is the start of the wiring diagram. I hope this helps. Please Rate this solution
Posted on May 20, 2009
  • 85 Answers
SOURCE: Wiring diagram for Pioneer DEH-P6550
black is negative blue is remote red is accesory key switch yellow is constant power memory,gray with black is RF negative and gray is positive white is LF positive and white black is LF negative.violet is RR positive and violet black is negative and green is LR positive and green black is negative
Posted on Sep 14, 2009
  • 1126 Answers
SOURCE: wiring diagram for pioneer deh-p3900mp?
Page 2 of 6 covers wiring diagram for DEH-P3900MP.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370942420DEHP3900MPInstallationManual1027.pdf
Posted on Oct 07, 2009
Pioneer DEH-X3500UI
Not much info. if it has removable faceplate make sure there is no debri and is toght fitting to the unit. make sure illumination wire is hooked properlt.
Feb 26, 2014 | Pioneer Car Audio & Video
Pioneer DEH-P5800MP CD Player not powering on.
did you try the fuse behind the wireharness. if so check the yellow wire and the red one for power. also check if you have ground on it. if you want to make things simpler try to connect the black wire to the battery neg. and the yellow and red together on the positive of the battery and see if it turns on.
Sep 01, 2009 | Pioneer DEH-P5800MP CD Player
Tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Mar 04, 2009 | Pioneer DEH-P6400 CD Player
Radio problems
does the radio also go out?
if not, then you miss wired something as in the orange wire or your after market wireharness adaptor is incorrect.
Recommend buying a repair manual to double check proper wiring
Jan 18, 2008 | Pioneer DEH-1900MP CD Player
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
