Question about Cuisinart DFP-14BC Custom Food Processor
Won't start; My machine worked fine when I gave to my wife last Christmas. Then for some reason would not go on. Finally I determined that the white plastic piece that pushes the rod down onto the safety switch was not functioning properly. Had to jury-rig a toothpick to hold the white piece in place (NOT a safe procedure I realize) but a short term fix. What can I do in the long-term? I tried the above sol'n as suggested but not my solution. Bowl and other parts all located properly; just that white plastic piece is NOT doing it's job.
    New Friend:
  • 52 Answers
A possibility that the micro switch inside which is actuated when you put the top on......the one you are tooth picking....has become dislodged, or the grooves that the switch hold it in place have broken off. Is there anything rattling inside the mixer which would suggest that a piece of the casing has broken off. If you can disassemble it to this point where you can see the switch and there is damage around that area which makes the switch loose, you could use some hot glue to hold it firmly in place. Let the hot glue set solid before you use it.....especially as the switch completes an electrical circuit and hot glue in its liquid form s conductive! Always remember to remove the electrical connection before opening the unit. Failing this, it could possibly be that the switch needs replacing which is a far easier job. Switches are pretty comparable regardless of what brand mixer. Sometimes held in with a screw on opposing corners. So even eBay would probably have one. Good luck. On the bright side, your solution works, but on the dark side, using a plug socket to switch a unit off and on is tricky! Saranden.
Posted on Nov 24, 2013
4 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: safety-rod of bowl does not depress microswitch of Cuisinart processor
Cuisinart does not have the original pieces available, but you can order a replacement work bowl, lid, sleeve, etc that will work from the company. First do a motor test to make sure the motor is still working:
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Posted on Nov 25, 2008
  • 17 Answers
SOURCE: motor switch not activating on a dfp-14ts
Is the cover assembly engaged and locked into place? If you can't lock the cover into place, it's possible that part of the plastic on the cover assembly is broken and not engaging the white rod inside the bowl. Determine which part is at fault (either the bowl or the cover assembly) and replace it.
Posted on Dec 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Won't start
Make sure the work bowl handle is locked in place so that it is facing the front of the processor (same side as the on and off switches).
Make sure the feed tube of the lid is facing toward the back of the processor and that the plastic or metal rod of the pusher sleeve is facing the back of the processor.
Note: this assembly only applies to the Cuisinart DFP-14 series - every Cuisinart has a slightly different assembly for it to turn on.
Posted on Sep 29, 2009
Wouldn't start:
Repair or replace is the simple answer but sometimes innovative solutions work just as well. The plastic piece-switch combination ensures that the machine cannot be started unless everything is in place properly.
Nov 24, 2013 | Cuisinart DFP-14BC Custom Food Processor
Need a blad-carrier
Check this site :
http://www.ereplacementparts.com/braun-food-processor-parts-c-120570_120574.html
They have got replacements for almost every parts.
Thank You.
Dec 27, 2012 | Food Processors
I have a cuisinart pro classic food processor, and even though bowl and top are locked in place, it will not start.
On the processor look at the bowl and lid and see where they are supposed to engage the motor. If this is broken then that is the problem, find something to push on where the part of the the bowl and lid assembly would push, if it comes on then you have figured out the problem.
Apr 17, 2010 | Cuisinart DLC-10S Pro Classic Food...
My Cuisinart Pro Classic is leaking! When I tried to make corn pudding at Christmas, something I've done many times before, the liquids poured out all over the counter. Everything seemed in place and the...
it is either the seal around the blade shaft that is worn (but if it is worn so much that liquids can leak, then you probably heard the machine vibrate more than normal or sound screechy). Or it is the gasket at the bottom of the container that is not seated well or is out of shape. Goodluck, Macgivor
Jan 16, 2010 | Cuisinart DLC-10S Pro Classic Food...
FOLLOWED MANUAL INSTRUCTIONS BUT MACHINE DOES NOT START. WHEN OWNER USED IT LAST IT WORKED. ATTEMPTED TO REFIT BUT COULD NOT GET IT STARTED. MACHINE WAS PLUGGED INTO GOOD POWER SOURCE, NOTHING WRONG WITH...
One of the major problems I have seen with food processors is the safety switch, which will not allow the motor to turn on if the bowl and top are not properly seated. The lever and/or switch sometimes wear to the point that they no longer work (easily). I'd do a bit more checking before I discarded the machine.
Oct 23, 2009 | Cuisinart Food Processors
The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Mar 12, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
DLC-7 missing a piece?
The workbowl has a spring-loaded assembly inside. You can see it through the plastic. When the workbowl cover is in place and locked, it depresses the button on the base. If this is not happening, then you need to determine whether the workbowl or the cover is at fault. Once you figure that out, you need to replace the faulty one. I usually get my replacement parts at GourmetDepot.com.
Dec 20, 2008 | Cuisinart DLC-5 Food Processor
Euro-Pro EP91 Quad-Blade 6 Won't Start
My wife was given this unit from an elderly gentleman that was done trying to make it work.
I just fixed the same problem as above. Note - I do not have a manual for this unit.
True above about the bowl cover being locked in position but found the key to make it work is also the white lid to the left of the bowl cover. I was locking and unlocking this white lid with no results. Then I removed the bowl cover and found the white lid cover was loose and easily removed this white lid to inspect inside ( why this cover removes I have no clue).
Anyway I was able to snap the white cover firmly on and turn counter clockwise to lock in place ( six o’clock position), then after putting the bowl cover back on and snapping in place it works.
Note - I do not need to turn the white lid cover to install or remove the clear bowl cover, this could be because it looks like one of the clear tabs might be broken on the locking area of the clear bowl cover. If you have two tabs the same shape on the bowl cover you may need twist the white lid clockwise to install and remove the bowl cover and counter clockwise to lock in place so the unit works, but now that my white lid is snapped firmly in place it hardly moves with the force of both hands trying to turn it.
Hope this helps someone.
Good Luck !
Dan L. P.
Jan 05, 2008 | Euro-Pro EP91 Quad-Blade Food Processor
Cuisinart DFP-14BC Custom Food Processor Logo
149 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
