Question about Waring MBB518 2Speed Blender
Need picture waring mbb518 blender motor
Hi, The motor on my blender was taken apart and then put back on incorrectly-resulting in a smoking smell and looking like the gaskets were destroyed. If anyone has a schematic of the order of assembly for the motor I would greatly appreciate it. I cannot find it on the waring site. Thanks.
  • 794 Answers
Go to the following link and locate your blender's model type: http://www.waringcommercialproducts.com/product-documents.php?type=parts
Posted on Nov 24, 2013
Testimonial: "Thank you for the help. Unfortunately, they didn't offer it for my model. I have heard that I can call the company directly and they will send me one. Thanks again."
4 Suggested Answers
SOURCE: Replace clutch assembly Waring BB150 Blender
Remove the little rubber feed on the bottom of the base (they might be glued a bit so be careful not to rip them). This will reveal 4 phillips head screws...remove them...this will open the base and reveal the back site of the rotor. In the middle you will see a turban blade like wheel with a large flat tip screw. Wedge a large screwdriver between the teeth of the old clutch so that when you turn the flat tip screw it will stop rotating the other end. Turn the screw with some force to the right to losen the clutch...then do the reverse to get the new one on tight...put everything back together and there you have it.
Keep in mind that this might void your warrenty if you still have some on it.
Posted on Nov 15, 2008
SOURCE: Waring P320CX blender parts required
Hi - there is a website called nisbets.co.uk that has all the spare parts for this Waring blender, plus a great diagram which is much better than anything in the blender instructions.
Posted on Jun 07, 2009
SOURCE: waring pro wpb blender emit burning smoke and
Obviously the motor winding is burned out. it needs to be rewound. This is can be done only by repair men who regularly wind motors.
All blenders have one thing in common. They draw more than rated current when running slow. If u continued using it inspite of noticing low speed then the it results in burnt motor winding as is the case now.
Also the blenders should not be run on no load, which will cause meahanical damage to fan and bearings.
Posted on Oct 17, 2009
Smoothie pro 600 manual
It means it's working very hard,
I suggest to put items that are thick in first and blend them then add the other ingredients after , the smell is the coating on the motor getting hot , if you see smoke coming out, drink your smoothie wash it out and take it back for a new one.
Jan 06, 2014 | Blenders
Blades won't spin
The motor may have failed.
Dec 25, 2013 | Cuisinart Blend & Cook Soup Maker
My blender is not chopping as well as it used to...sometimes not spinning at all.
The motor may becoming weak. You may not observe much difference between the two speeds
Nov 27, 2013 | Waring MBB518 2Speed Blender
Replacement end coupling
Possibly an appliance parts supplier can help.
Nov 27, 2013 | Waring WSB40 Blender
Does anyone have a schematic showing how to put the motor back together. mine was taken apart, and now I can't find the washers and need to replace and put everything back together correctly. any help...
follow this steps . God bless you
  1. Unplug the blender and remove the jar. Undo the screws securing the baseplate. Separate the baseplate and attached motor collar from the base housing.
  2. To remove the switch housing, remove the decorative facing to get at the top screws. Remove the lower screws from inside the blender base.
  3. Hold the fan to keep the motor shaft from turning as you unscrew the drive stud. Remove the shield and any washers. Unscrew the fan nut to remove the fan.
  4. Disengage the strain-relief fitting from the housing. Remove the wire connector joining the power cord and the lead to the brush housing.
  5. Label and disconnect the lead wires from the switch block. Remove the motor mounting bolts and lift out the motor if necessary.
  6. To free brushes, remove the leads attached to the brush housing. Use a screwdriver to press lead terminal through the slot in housing. The brush spring may pop out (don't lose it!).
Nov 24, 2013 | Waring MBB518 2Speed Blender
Waring pro wpb blender emit burning smoke and smell when i was blending ...
Oct 16, 2009 | Waring WPB 01 / 04 / 05 / 09 Professional...
Burning smell when used
No need to oil it. The carbon brush maybe sparking already it is located inside the motor. It is due to damaged Armature or overloaded motor.
May 25, 2009 | Waring BB160 2 Speed Blender
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Waring MBB518 2Speed Blender Logo
145 people viewed this question
Top Waring Blenders Experts
karen renee may
Level 1 Expert
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
