Question about 1997 Chevy C/K Pickup 1500 Performance Exhaust System
Lower intake manifold torque specs for 97 yukon1500/5.7
Lower intake manifold torque specs for 5.7 liter
  • 3 Answers
The lower intake bolts for your manifold are in three steps. step 1 is 27-inch pounds, step 2 is 106 inch pounds and step 3 is 11 pounds. you have 8 bolts. the first bolt u start with is the second one on the left looking at the motor, then the third on the right is number two, straight across to third bolt on left, back to second bolt on right, the 5th bolt is the far left corner and 6th is straight across to right, seventh is the first bolt on left and 8 is to the right. hope this helps you out.
Posted on Dec 29, 2013
Intake manifold torque specs 2000 olds silhoutte 3.4
Follow the link for a complete listing of this engines bolt torque specs. Torque Specs Database
Jan 25, 2017 | 2000 Oldsmobile Silhouette
The torque specs when replacing the inake gaskets on a 97 Lumina 3.1 liter enne
The torque specification is a 2-step process; tighten the vertical lower intake manifold bolts (the four middle ones) to 7 Nm (62 lb in). Tighten the diagonal lower intake manifold bolts (two on each end) to 7 Nm (62 lb in). Tighten the vertical lower intake manifold bolts (the four middle ones) to 13 Nm (115 lb in). Tighten the diagonal lower intake manifold bolts (two on each end) to 25 Nm (18 lb ft).
Upper Intake Manifold
Tighten Bolt/stud 25 Nm (18 ft. lbs)
Notice inch pounds and foot pounds. 62 inch pounds is 5.2 foot pounds.
Jan 05, 2017 | Cars & Trucks
98 ford windstar intake manifold torque specs
Intake torque specs ' FordForumsOnline.com
www.fordforumsonline.com > Ford Tech Forums > Engine & Drivetrain
May 7, 2010 - 2 posts - ‎2 authors
ISO torque specs for the intake & plenum for a 98 Windstar...3.8 with the ... Our community is here to help you with any questions you have related to your Ford. ... Lower Intake Manifold to Cylinder Head Bolt 8-12 - (71-106).
Torque Specifications - AutoZone
www.autozone.com/.../Ford-Windstar.../Specifications/Torque-...
AutoZoneAutoZone Repair Guide for your 2004 Ford Truck Ranger 2WD 2.3L MFI DOHC 4cyl Engine Mechanical Specifications Torque Specifications. ... Ford Windstar 1999-2003 ... Bolts, Main Bearing Bolts, Rod Brearing Bolts, Crankshaft Damper Bolts, Flywheel Bolts, Manifold. Intake, Exhaust ... Vehicle: 2008 Ford F150, 98 Civic.
Dec 21, 2015 | 1998 Ford Windstar
What are the intake manifold torque specs on a 2005 Pontiac grand Prix gtp 3.4 liter with super charger?
If it were mine, I'd want to be very sure what it was and so I always use a Repair Manual I can see and read, but that me.
Mar 13, 2015 | 2005 Pontiac Grand Prix GTP
Intake manifold torque specs.
It is criss cross from front to back around 15 foot pounds so snugging them with a ratchet should do the trick
May 17, 2014 | 2008 Mercedes-Benz Mercedes Benz C Class
3.5L oldsmobile intrigue intake manifold sequence and spec torque
Tighten the vertical lower intake manifold bolts (the four middle ones) to 7 Nm (62 lb in). Tighten the diagonal lower intake manifold bolts (two on each end) to7 Nm (62 lb in). Tighten the vertical lower intake manifold bolts (the four middle ones) to 13 Nm (115 lb in). Tighten the diagonal lower intake manifold bolts (two on each end) to 25 Nm (18 lb ft).
Oct 11, 2013 | Cars & Trucks
What are the torque specifications for the intake manifold on a 2003 Ford F150 4.2 liter engine?
These torque specs are from the Haynes manual (Ford pick-ups 97' - 03') This is a 2- step proccess. step-1 44-in-lbs step-2 89-in-lbs. There are 14 bolts that hold the manifold in place, tightening sequence goes as follows: start from the center( WORK IN A "X" PATTERN)
Oct 02, 2010 | 2003 Ford F150 Regular Cab
1997 Chevy C/K Pickup 1500 Performance Exhaust System Logo
67 people viewed this question
Top Gibson Vehicle Parts & Accessories Experts
Marvin Steele
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gibson Vehicle Part and Accessory Expert? Answer questions, earn points and help others
