Question about HP Computers & Internet
Idle printer status
My printer status is showing offline it needs to be shown in idle position how do l get it into the idle setting
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
If your computer is USB connected make sure that the cable is connected and that the printer is powered up. If you are connected to the printer over your network through wifi or ethernet, make sure that each device (computer and printer) is connected.
If all of these are in order and the printer still shows offline, try re-installing the software that came with the printer. Sometimes the software needs to be re-installed due to corrupted files.
Posted on Dec 10, 2013
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Keeps telling me the printer is offline
Step 1:
b. Click Printer.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
Update drivers: recommended links
http://windows.microsoft.com/en-US/windows-vista/Update-drivers-recommended-links
Source: Samsung SCX 5635FN Manual
Mar 02, 2014 | Samsung SCX-5635FN All-In-One Laser...
Printer offline wont print cant get back online
Step 1:
b. Click Printer.
Step 2:
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
My printer says it is offline but the status monitor at the bottom of the screen says its ready... but will not print.. whats going on?
I've been suffering the same problem, but I think I havefound a solution. I have a MFC9320CW. It was showing 'ready' on the computer,but 'offline' on the Status Monitor.
My printer is set up to go to sleep after 5mins. I thought this was a problem,as initially it looked like it was in a coma, but it turns out it's ok.
I installed the software on my desktop (windows7) and after a bit of time thestatus monitor turned from offline to sleep. From here you can go into the(CC3) ControlCentre3 ->Device settings -> Remote setup and enter thepassword = access. Please note if the status monitor is showing offline youwill get an error message. A new window opens up. I went down to -> WLAN-> TCP/IP and then I changed the IP address, subnet mask and IP gatewaysettings, I also changed IPv6 to enabled. I applied these settings and then theprinter appeared to work as I expected it to.
I got the IP address etc from the printout I got when I initially set up theprinter.
I've been able to scan through the CC3 at my desktop; from the printer and thescan has gone to the desktop; and also from Adobe Acrobat8 at my desktop. I then set up a laptop (vista), first off I uninstalled allthe Brother software I had put on it as I'd managed to put the software onseveral times. When I installed the new software I chose the option MFL-Prowithout paperport11. When the status monitor opened and it was in the sleepmode I went to the CC3 -> Device settings -> WLAN and found all thesettings had been adjusted to those I had set for the printer at the desktop. I've now gone through installing it on a second laptop (XP).Again uninstalled previous attempts, then reinstalled MFL-Pro without paperport11 and this too is now working. So, if need be uninstall then install the software again.When you get the status monitor showing sleep/ready go into the ControlCentre3,change the settings as above, then all should be well. Since changing these settings the status monitor hasn't yetgone back to offline. I'd struggled for days before I got it sorted; the onlinehelp hadn't been much help. I hope this helps.
Jan 19, 2011 | Brother HL-2040 Laser Printer
Printer Offline Message
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Get more information to fix printer offline error :
http://printers.iyogi.com/errors/printer-offline-message.html
Hope this information helps you.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Print status: error - offline what does this mean? I have a PSC 2355 all-in-one
Printer status offline means that, the printer driver and the application has been installed, but the printer and it spooler services are idle
To resolve this issue:
Goto control panel, click on printers and faxes, a window will open showing you all the printers you have or have had. The current printer will have a checked mark. Highlight it and right click, you will see printer offline in the box, click it. That will turn the printer online and you can print.
Dec 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Computers & Internet Logo
142 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
