Question about Microwave Ovens
Smoking oven what causes my Oster microwave to smoke?
MicrowaveSvc
  • 9047 Answers
SOURCE: faint buzzing sound smoke coming from back
The high-voltage transformer (or inverter transformer) has probably failed.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Nov 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Posted on Nov 27, 2008
  • 13 Answers
SOURCE: ge microwave oven wall smelling wire burn!!!!
time to put it to rest
Posted on Jan 02, 2009
co7196
  • 3433 Answers
SOURCE: smoke came out of the door of the microwave oven
Have it replaced.
Posted on Jul 05, 2009
heatman101
  • 43501 Answers
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
Smoke coming from under oven
You need a new microwave or you need an appliance repairman. Usually smoke in an electronic product means that there is a short in the wiring or overheating circuit board. If it is still under warranty take it back where you got it.
Nov 26, 2014 | Daewoo KOC-925T Microwave Oven
Microwave started smoking when i turned it on
Unplug the microwave and take it out check if any food items were present before u put oat meal inside it.IF there in nothing then check for any wire leaks.The smoke may have been caused by leakages in the microwave wire.Check both the things
Dec 07, 2011 | Panasonic NNSD697S Stainless Steel 1300...
Microwave is making humming noise and started to smoke and stop working
sounds like the fan inside oven seized, causing the smoke and popped the internal fuse. If you have any appliance repair shops around, they should be able to fix it for you cheaper than replacing the entire unit. Make sure you leave it unplugged, I know thats abvious but had to mention. Good Luck!
Apr 18, 2011 | LG LMV1630ST Microwave Oven
My Kenmore OTR Convention microwave oven started smoking an awful smelly smoke or gas then stopped working. Can this be fixed? Thank you so much!
It probably cannot be economically fixed...
heatman101
Apr 13, 2011 | Kenmore 80809 Microwave Oven
Microwave stopped working with no warning. They had a recall on this model and since they ordered two parts it has not worked right
Just had my Kitchen Aid Microwave KHMS155LSS burn up and bellow smoke.
Thankfully, I was close by, stopped the microwave, vented the smoke, turned off the circuit breaker and unplugged it. Still the smell of burned motor, burned plastic has me concerned. Did it get hot enough to cause problems behind the drywall? So far, I am keeping a "fire watch" to make sure nothing is smoldering.
Feb 12, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
We put a plastic jar with a very small piece of foil on the rim and the microwave started to smoke. it might have run 30 seconds before we noticed it making a funny noise. it is a 1200 watt inverter
Hello Dwight,
You may have damaged the microwave. Since the oven cavity is a tuned cavity, introducing metal into it can wreck havoc on the magnetron (microwave generator itself).
Did you happen to notice if the smoke was from the plastic jar (plastic heating up from the high temp of the foil ring), or if it was the actual microwave smoking (and not blowing smoke out of the oven cavity from the plastic jar)?
Sep 14, 2010 | Panasonic MCM INVERTER
My microwave roof suddenly started giving smoke and the microwave safe container melted
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The capacitor went up in smoke..
heatman101
Sep 01, 2010 | LG Microwave Ovens
OSTER MICROWAVE 1.1 MOD OGF41101-RUNS BUT WON'T HEAT.
There are two fuses in a microwave oven, and for the non-heating problem the problem is the high voltage fuse, incapsulated between the transfo and the magnetron. This supports up to 5000V and usually rated something like 0.65A/0.7A/0.8A and even 1A.
When you open the capsule, you'll see it sitting there between its two connectors, and you'll notice the filament inside the glace is broken. Buy a new one and your machine will work like a horse.
NOTE: Try to get the same ratings fuse, or else the oven will smoke and smoke the house with it, so be careful.
The other fuse is smaller, and usually ceramic one, which can be found on the PCB, if that goes, you should get no power at all to the machine. If not sure, let a professional do the job, it's safer.
Apr 09, 2010 | Westpoint TV-201 Microwave Oven
Stove fire smoke on microwave above stove.what will clean off this smoke residue? we encountered a stove which left a heavy smoke residue on the microwave above. the microwave has a plastic handle and...
Mr. Muscle Kitchen cleaner will remove the smoke. It won't hurt the plastic. Just make sure to either wear rubber gloves or wash your hands soon after cleaning off the smoke residue. It will make the skin on your hands / fingers slick and then dry after your done. Let the cleaner sit for about a minute before trying to wipe off the smoke residue.
Mar 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
3 new or fairly new microwaves same problem????
Did you properly orient the exhaust vent and take out any shipping materials under the exhaust vent? Sounds like the exhaust fan itself may be overheating, smoking up the innards of the microwave and then the smoke is escaping though the hole where the carousel is located.
Either that or someone built the shaft of the carousel rotator out of the wrong material and the microwave is actually trying to cook (or arc) that piece, causing a fire.
Neat stuff!
Mar 05, 2009 | Microwave Ovens
Microwave Ovens Logo
12 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
