Question about Garden
Cannot get old muffler off Morrison Vinaro 350ST
2 Suggested Answers
SOURCE: Morrison vinaro mower manual
hi there
i bought a brand new morrison lawn mower, briggs and stratton 450 series, 148cc
i dont know how to open the oil bit to fill? it looks like you twist but ive tried several times with no luck
can you help me please
thanks
Posted on Jan 31, 2012
Tip
RECYCLE THAT OLD CATALYTIC CONVERTER
Sooner or later, most cars will need to have one or more catalytic converters replaced. The old converter off your car or truck can be recycled for cash. Some of the older converters are worth enough to pay for having a new one installed. But most people are not aware of how valuable they are, so they let the muffler shop or repair shop keep the old converter. The muffler shop will recycle the old converters for money that should have gone in your pocket. Personally, I think there should be a law that requires the muffler shops to give the old converters to the customer, or have the customer sign a waiver saying they do not wish to keep the old converter. The waiver should state that the converter can be recycled for cash. And if they waive their right to keep the old converter, the muffler shop should be required to reduce the cost of the new replacement converter by a percentage of the value of the old converter.
on Feb 10, 2011 | Chevrolet 1500 Cars & Trucks
Mt Morrison Vinaro lawn mower won't turn off.
I am guessing that when you put the throttle off you make a switch that grounds the spark from your coil (feeds your spark plug) to your chassis. When this is grounded the engine does not get a spark and stops. So check that there is a wire connected to your coil (you can find the coil by tracing the High Tension lead back from the spark plug). One you find it disconnect from the coil and with the throttle off you can test for continuity between the end you have and the engine casing. If you don't have continuity you have a broken cable or the switch in the throttle isn't working. should be an easy fix
Dec 09, 2013 | Garden
Morrison weedeater
never saw your brand weed eater . but most weed eaters ,the string cap either unscrews or has plastic tabs that have to be pushed sideways with a flat blade screwdriver.If you have the plastic tabs ,be careful not to crack them off when pushing them sideways with a screwdriver--- so that the nub can clear the slot and get the cap off.
for better info call morrison customer service and ask.
phone # on weed eater and in owners manual. also , owners manual should have instructions under how to change string.
a pdf manual can be downloaded from morrison weed eater.
you will need to know your model number before morrison can help you.
Oct 06, 2013 | Garden
I have a Morrison bc325s2 and need a user manual
Type a web search: morrison bc325s2 user manual
Jan 26, 2013 | Cameras
hi there
thanks
Oct 30, 2011 | Garden
Hi, I'm having problems starting my new morrison bc230b weedeater... I think whats happened is the wrong fuel was put in it..(no oil mixed) .is there a quick fix? thanks
hi there
walkersworld
if you have run the unit with no oil in the mix ie straight petrol
you will have damaged the piston / rings / bore - do a compression check - if its quite low
check - remove the muffler and check for score marks on piston and rings and bore
if so , the unit may not be worth repair , because compression will be lost past damaged rings
and with damage on piston more scoring / damage will occur
so answer to is there a quick fix - no especaily if what find when you look up the ex port at piston / rings/bore
have a look
sorry for bad news
pauly46
May 31, 2011 | Garden
Do i need any special parts to replace a muffler on chev truck 1994? It appers the old muffler is welded on one side.
you will need a torch kit, as you will have to cut off the old muffler and weld on the new one.
Oct 14, 2010 | Chevrolet C1500 Cars & Trucks
Morrison 1400W electric lawn mower goes for 20 secs.
I would think that switch may be faulty? Or is it a momentary switch only?, if so, then you have an input to the controller problem, insomuch as it starts, runs, for some reason thinks there is a problem & shuts down, whereby the switch is being pressed, so it "Sees" this and starts again, and so on?
Mar 04, 2010 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
