Question about Philips Magnavox TS3260C 32" TV
Tv picture is broken into vertical lines
The television splits the picture into vertical lines. The lines are closely spaced together, but are still obvious. It's like looking at a photo after its been through the shredder. Otherwise, the TV works fine. About 4 years ago, we had a problem with the resistor( and found the fix on this website)
  • Charity Smalls
    Charity Smalls Dec 02, 2013
    Hi, Carl! Thank you very much for your suggestion. As it turns out, the cable box needed to be reset. The telly's fine now.
The TV may have blown out. Time for a new one are you can reset you TV. Hope This Helped
Posted on Nov 24, 2013
  • 1694 Answers
SOURCE: Tv problem
Bad capacitor in vertical output IC circuit + check power supply
Last, replace IC.......................T.
Posted on Nov 21, 2007
  • 476 Answers
SOURCE: mkgregory
If the TV supports it, you can go into service mode by press ing the following on the remote control:
062596 i
This will take you into a service menu. It also changes channel as you press the keys, so change to a used channel to get a picture back.
I am not familiar with this model, but the principles should be the same.
Using the remote control to navigate the menu, you are looking for "allignments", and from there "Vertical Amplitude" or V/AMP or VA or similar.
BE CAREFUL when making adjustments, as you can permanently damage the TV if you adjust any critical settings.
When making changes, make a note of the original setting so you can put it back if its not the right option. Also only make changes 1 notch at a time. It will be obvious when you have the correct option, so if nothing is happening after 2 or 3 notches, then put it back. This will minimise risk to the TV.
When you have finished, look for a "Save settings" option, if not just press standby to get out of the service menu.
Posted on Feb 23, 2008
Ecollier2012
  • 3459 Answers
SOURCE: TV picture was warped, no it is black, but the power light remains on...
I had a similar problem. Started out with the video shrinking and expanding. Then just recently it just broke- the TV would power on but I had no audio or video.
Its now fixed
You can find a repair kit here.
http://www.magnavoxhelp.com
Posted on Jun 21, 2008
Siestamagic
  • 6 Answers
SOURCE: Philips 27PT6441 27" TV Problem
jon5902,
Pls note that my experience is with the phillips 27" model27PT6341/07. It may not be the same board as yr model, as I can't remember nor find the service manual anymore. (browse around online for it though)
However, after taking the back off. Look close to the rca jack and svideo connection. Mine is located about an inch from the svideo connection.
Here are some pics that may help you.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
The new one is the black and gold one marked 10uf 100v in the pic.
Other users have advised to go as high as 10uf 250v, to avoid having the cap overload again.
PS. I had the lines for about 2 weeks. They got steadily worse then one day my tv looked like it was broadcasting an hourglass. The lines converged in the center and flared outward (no pic).
Posted on Sep 12, 2008
  • 4234 Answers
SOURCE: blue,red,green lines on top of screen for couple months. Now tv wont work.
The foldover is because of a bad capacitor in the vertical circuit. Given the "new" sympotom of a dead set, I would suspect that the vertical IC has failed. This should be a relatively simple repair for a TV shop. If you wish to attempt a repair of this yourself, update this and confirm your model number and I'll post more details and instructions.
Dan
Posted on Nov 14, 2008
How do you fix white vertical lines on Vizio tv.
Any horizontal or vertical lines on a LCD pane, 90% the chance that is a defective LCD panel.
Aug 01, 2017 | Vizio Televison & Video
Vertical lines
I called a local tv repair shop he said that he'd have the see the unit to give an exact price but their labor rates were from $79.95-$179.95 + parts =(
Jan 10, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Upper 1/4 of picture is distorted by tightly spaced horizontal lines. What do you think is causing this?
This sounds like a vertical fold over.
This happens when the filter capacitors close to the vertical IC have failed or changed value. The are very inexpensive, and relatively easy to replace.
Remove the back panel. Locate the vertical IC. There will be a number of capacitors around it (3-4). I just replace them all. They cost under $1 each, so no testing, just change them.
Jan 02, 2011 | Toshiba 27A44 27" TV
Line across the tv no sound no picture
If you look carefully at teh line it should be red, green, and blue close together to appear like a white line. If this is the case, then the vertical circuit has failed. This is often poor solder connections at the vertical IC or a defective IC. Expect a parts cost in the $20 range for this repair.
Dan
May 04, 2010 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Green Lines with Picture behind
Could be serious...but first check the screen modes (for split screen, format, etc) to be sure the tv is set up properly for the picture you are trying to watch. Switch the input to a DVD or something similar. Is it the same? If not, you have a mode/resolution problem with the tuner and perhaps some other device.
Jun 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv toshiba vertical problem
I had white lines 4" thick vertically for about a week, then one day powered the unit up and with in 3 seconds there was a loud pop from the rear or the unit. Any one know what needs to be replaced?
Jan 23, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Picture problem
try to put away any electric device which is near your tv set
Nov 25, 2007 | Samsung HLN4365W 43" Rear Projection...
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Philips Magnavox TS3260C 32" TV Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
