Question about Dell Inspiron 1000 Notebook
Would like a circuit diagram for dell inspiron 1000 power circuit
The power cord was accidentally connected with the polarity reversed. Now the battery will not charge with the polarity corrected even though the cord succesfully charges other computer batteries.
    Master:
  • 507 Answers
Does the laptop still work?
You don't mention that..
Some laptops have a protective diode inside for this very reason..
Posted on Nov 24, 2013
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
There is a reverse polarity diode that prob popped. It doesn't allow the power to even reach the battery anymore. It'll prob charge in another laptop that takes that battery. The diode is on the mother board.
DJ Wildman
  • 10 Answers
SOURCE: My power cord not charging battery
you may have damaged the power input port.
broken solder joint. or your power supply took a dive. if you have a DMM 'meter' check the power supply to see if you are getting power from it.
if it is the power input port, you will have to either open up the laptop and see if it is a fixable soldering job or take it to a pro.
Happy Fixing =)
Posted on Jul 11, 2009
daddyofdudes
  • 3 Answers
SOURCE: Inspiron 8600 does not charge batteries. Power
in these case u have to take one star screwdriver. carefully remove all screws n check the battery slot is it broken. if it is , den u have to change the slot.its just the connections problem. no prob with board. so dont worry ur works again.
Posted on Aug 16, 2009
joelwilcox
  • 1274 Answers
SOURCE: Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Posted on Nov 06, 2009
joecoolvette
  • 5660 Answers
SOURCE: Dell Inspiron B130 - can you replace the
The port on the laptop where the AC adapter plug goes into, is the DC Power Jack.
The DC Power Jack for the Dell Inspiron B130 Notebook PC, is soldered directly to the motherboard.
[Some laptop designs have a cable, that goes from the motherboard, to the jack. The jack is separate from the motherboard.
Some have a separate circuit board that the jack is soldered to. Referred to as a Power Board, (Circuit board) This circuit board plugs into the motherboard]
This is Dell Support, and the main page for the Service Manual - Dell Inspiron B130,
http://support.dell.com/support/edocs/systems/ins1300/en/sm/index.htm
The DC Power Jack is connected to the back of the motherboard.
1) The power sources for the laptop are removed. AC adapter, and Battery.
2) An ESD wrist s-trap is worn, and the alligator clip is attached to a good ground source.
(Electro Static Discharge. The above is an antistatic device that is worn around the wrist, and has a cable coming from the wrist s-trap. At the other end of the cable is an alligator clip. The clip is attached to a good ground source. I use an empty desktop computer case, and connect to the metal frame.
Your body carries Static electricity. Static, will fry out the delicate hardware components inside a computer, in a flash! Poof!
You won't see it, or feel it.
An antistatic device like the above, helps to insure this will not occur.
Average cost is $6)
3) The entire laptop, is disassembled down to the bare motherboard in your hand. (Except for the LCD screen assembly)
[There may be as many as 60 screws, and 12 different types of screws. Some look the same, but they Are Not.
A multi-compartment container should be used, and the different compartments, labeled for the area the screw/s came out of.
You can use a clean egg carton in a pinch]
4) The DC Power Jack is removed, using techniques for un-soldering electronic components.
(I usually use Desoldering Braid, {Also known as Solder Wick}, instead of a Desoldering Tool. Works much better. The melted solder is taken up by the braid, and the solder is removed a little at a time)
A) If the circuit trace is heated too much, by lingering with the soldering iron, (Or soldering iron attached to a Soldering Station), the circuit trace may lift right off of the motherboard.
This renders the motherboard useless.
B) If too large a wattage of a soldering iron is used, or a soldering tip that is too large, the circuit trace can lift right off of the motherboard.
Too much heat.
Renders the entire motherboard useless.
(Think of a circuit trace as being a very flat, thin, tiny copper wire)
The circuit trace area where the Prongs, or Leads, of the DC Power Jack go down through, is tinned already with solder.
If too much heat is applied by A), or B) above, this area can be rendered useless.
The area will no longer accept solder. You can't make a solder joint again in this area.
(The circuit trace area that I am describing, is a small area around a hole in the motherboard. The DC Power jack has pins, (Properly referred to as Prongs, or Leads), that go down through these holes)
If this occurs you might as well take your motherboard, and use it for a Frisbee.
This is the what a replacement DC Power Jack looks like, for a Dell Inspiron B130 laptop,
http://www.megaemarket.com/dc-power-jack-for-dell-inspiron-laptop-b12120130.html
You can click on the photo to enlarge it. The photo shows the jack upside down, in relation to how it sits on the motherboard.
Those flat metal pins you see sticking up are the Prongs, or Leads for the jack.
In the right side of the photo, you can see the Lead that comes up in the middle, on the back of the jack. The lead is riveted to the jack. This view shows the back of the DC Power Jack.
This is the Positive connection.
The Positive connection goes to the pin in the center of the jack.
The lead immediately on the left of it, is the Negative connection.
The Negative connection goes to the strip of metal, in the outer part of the DC Power Jack hole.
The outside metal shell of the AC adapter plug contacts it.
5) The circuit trace area for the DC Power Jack's lead's, is cleaned well, and re-tinned with solder.
The new DC Power Jack is installed, and the leads are soldered.
Soldering must be done correctly.
Linger too long while soldering, and you'll cause A) and B) above. Don't keep the soldering iron tip there long enough, and you'll create a Cold solder joint. Or disturb the solder joint before it has properly cooled, and you'll create a cold solder joint.
(Soldering time is usually about a 3 to 4 second window of time)
This technique is usually done by a professional, competent, computer repair tech.
Seems like there are fewer, and fewer of them.
The easy way is just to replace the entire motherboard.
(Also generates more money for the computer repair shop, and the technical skill required is a whole lot less)
This may be an avenue you wish to approach. Don't know. Don't know your soldering skills.
(I have found that Ebay has a lot of laptop motherboards for sale.
Not advertising for Ebay)
Posted on Dec 30, 2009
djfrankn
  • 100 Answers
SOURCE: Dell Inspiron 1000 won't turn on. It is always
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet.
Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Posted on Jan 03, 2010
How to wiring the power cord to the F/R switch?
Will need more information: make, model, etc. A corded drill motor can be AC or DC. It can be variable speed on not. An AC motor can be reversed by changing the magnetic polarity of the start winding (switching the two start winding wires). This type of wiring in not usually variable speed. A DC motor is reversed by changing the electrical polarity of the primary motor leads. Usually these type of devices have a rectifier circuit to produce DC voltage and use a PWM signal to develop variable speed.
Sep 24, 2014 | Drills
Polarity
As long as you buy a genuine Dell AC adapter, it will be find.
Do not buy a 3rd party AC adapter.
I have bought at least a dozen Dell AC adapters on eBay. Just make sure the photo shows a genuine Dell.
http://www.ebay.co.uk/itm/Original-OEM-Dell-Inspiron-Mini-10v-Battery-Charger-Power-Supply-Cord-19V-30W-/190678344193
Apr 15, 2014 | Dell Inspiron Mini 10 Notebook
Lincoln Arc Welder AC 225 Wiring Diagram
won't have reverse polarity. There are only 3 wires, 2 power and one ground. It does not matter what power lead goes to what side.
Apr 19, 2012 | Lincoln Electric K1170 AC-225 Stick Welder
My inspiron 1000 laptop from dell won't turn on. The adapter cord is not getting hot. I was defragging the computer when it shut off. Is this the adapter cord?
Hello there:
ok the first thing that i would suggest is to remove the battery and unplug the power cord from the computer
now check the area that the battery connects to and get a q-tip and some rubbing alcohol and clean the contact areas where the battery connects to the computer at really good and let dry
next if the computer has a reset hole on the back of it use a toothpick or somthing small and press in on the reset for 2 min and than release than press and hold in on the computers power on button for one minute and release now plug in only the power cord and turn on the computer and it should now start
than after it does put the battery in and let charge for a min of 30 min
than you should be ok from there ok
Please feel free to post a comment to me if you still have problems ok
Hope all of this is very helpful for you
Best regards Michael
Dec 19, 2009 | Dell Inspiron 1000 Notebook
Vostro 1000 wont charge also 2nd machine same model has a ic blown on mainboard where can i get a schematic diagram also is there a general known fault with the charging circuiton this model . Rgds
Schematics for Dells are generally unavailable.
The not charging is normally due to a failure on the charging circuit or damage to the power plug (If ac adapter will not run system or if you have to play with the power connection.)
Replacement motherboards start at about $75
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1000+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=dell+1000+motherboard&_osacat=0
Oct 06, 2009 | Dell Vostro 1000 Notebook
Inspiron 1000 green lights come on, no fans, blank dark screen, no cursor
Check your RAM chips. A bad RAM chip will cause this symptom. Could also be a bad MB. But check the RAM first since it's a much cheaper fix. Might also just need to be reseated. After reseating, pull the battery and power cord. Press the power button for about 10 seconds. Then reinstall battery and power cord and try to reboot. If symptom persists, it's likely the MB.
Sep 16, 2009 | Dell Inspiron 1000 Notebook
Cannot connect a hp psc 2410 printer to dell inspiron 1000 laptop
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
May 27, 2009 | Dell Inspiron 1000 Notebook
I Need to locate the laptop reset button on it
to reset most labtops all you have to do is hold down the power button for about 15 seconds and it should reset
Mar 25, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
71 people viewed this question
Alun Cox
