Question about Magic Chef Refrigerators
Magic chef french door fridge only cools on the bottom
The fridge is cool on the bottom, but the closer you get to the top there is no cooling. We have recharged with coolant with no change.
    Top Expert:
  • Magic Chef Master
  • 12,962 Answers
If you charged the unit yourself the only thing I can think of is that you did not charge it properly. Refrigerators are not like AC units - the amount of charge, measured in ounces is very critical. You have to be right on the money lest it not cool properly.
If you have access to gauges and you are using the AC refrigerant normally used for cars, the pressure at ambient room temperature of 78 degrees should be around zero. Let the unit run for about thirty minutes to stabilize pressures and then do the reading. If room temp is higher than 78, then pressure can be a tad higher but no more than oupounds.
If no gauges, then allow unit to stabilize and then observe the temperature and condition of the suction line to the compressor. On a properly functioning unit the line should be cold to the touch and maybe sweating or beading. If it is warm to the touch you are low on refrigerant - add small amounts slowly till pipe cools. If you have frost forming on the pipe going to compressor the unit is overfilled and you have to bleed it slowly till it is cold and wet, not covered with frost.
Insufficient cooling is also caused by a improperly working freezer defrost mechanism whereby ice accumulates in freezer compartment. Here the culprit is either the defrost timer and or defrost heater element.
Posted on Nov 28, 2013
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
SOURCE: freezer works, fridge is not cooling
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerant is not circulating well....... please visit your service authority
Posted on May 14, 2009
SOURCE: Magic Chef Refrigerator
I've had a lot of experience with this problem in Magic Chef refrigerators. It was the fan motor in the freezer section not working. It is a fairly easy item to change out and the part runs about $40.
Posted on Jun 11, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Fridge not cooling
We will need to see if yours has the defrost timer or the adaptive defrost. Let me know if your model is the JSD2789GES. I have the manual we can work with. ..Sea Breeze
Posted on Jun 21, 2009
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
THE FREEZER WORKS BUT THE FRIDGE PART DOESN'T. IT'S THE SMALLEST SIZE 2 DOOR FROST FREE MAGIC CHEF FRIDGE. ABOUT A YEAR AND A HALF OLD. WHAT SHOULD I DO?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 16, 2010 | Magic Chef Refrigerators
Water collecting on shelf above veggie drawer in Magic Chef refrigerator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 15, 2010 | Magic Chef CTF2125 Top Freezer...
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
Hello, i have a magic chef fridge and im trying
It is ok to tilt frige back for hinge access be sure to unplug it and brace it so it doesn't fall on you.
Nov 04, 2009 | Magic Chef CTF2126AR Top Freezer...
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Our Magic Chef fridge model # MCBR1000W does not seem to be keeping the fridge part cool enough, but still keeps the items in the freezer section frozen. The compressor is working, so not sure why this is...
yes the freezer door not closing properly will effect the refrigerator. also check in the freezer back wall and bottom for any frost buildup. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Magic Chef Refrigerators
Refrigerators Logo
37 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
