MUSKOKA MES32BL-2 WIRING DIAGRAM - Heating & Cooling
Muskoka mfb28-2
There is a capacitor that is bad. The capacitor regulates the phase of an AC motor. It looks like a can shaped object.
Dec 12, 2013 | Garden
Where did Adirondack Chairs get their name?
Adirondack Chairs are also known as the Muskoka chair. Adirondack is the name of the mountains West Port NY where the inventor Thomas Lee needed chairs for his summer home. Muskoka as in Muskoka Ontario.
Jan 17, 2013 | Garden
Muskoka electric fireplace ,the switch doesnt work
  • Unplug the fireplace
  • Open up the fireplace to gain access to the inside.
  • Inspect switch for charring, melting, etc.
  • Inspect circuit board for charring etc.
  • If indeed the switch is the culprit: then...
  • Unhook the wires from the switch.
  • Remove the switch.
  • Bring the switch into your local hardware store or radio shack.
  • Buy a compatible switch - pay attention to amperage markings etc. so your new switch can handle the power.
  • Install new switch and re-hook up the wiring.
  • Close up the fireplace and enjoy...
Nov 25, 2012 | Heating & Cooling
Why are Adirondack chairs also referred to as Muskoka chairs?
These chairs were given the name Muskoka chairs due to the popularity of them used in the area of Muskoka, Ontario (a cottage country area north of Toronto, Canada).
Aug 26, 2012 | Adams Garden
Adirondack Chairs are also known as the Muskoka chair. Adirondack is the name ofthe mountains West Port NY where the inventor ThomasLee needed chairs for his summer home. Muskoka as in Muskoka Ontario.
May 29, 2012 | Garden
I would like to know how to repair the on/off switch on a Muskoka electric stove model MES30BL-1. Thank you.
I have a Muskoka MES30BL-3 Phoneix electric stove. I turn on, it stays on a little bit and then goes off. What's wrong?
Mar 22, 2011 | Kitchen Appliances - Others
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
2002 ford f150 4.2l wiring diagram
The COIL PACK TOWERS are numbered : coil----3---4 pack---2---6 plug----1---5 ----------------------------------------------------------------- The engine cylinders / spark plugs are numbered : passenger side , front to rear , 1 , 2 , 3 -----drivers side , front to rear , 4 , 5 , 6 ------------------------------------------------------------------- The spark plug firing order is ( 1 -4 - 2 - 5 - 3 - 6 )
Apr 07, 2010 | 2004 Ford F150
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
