Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak 2150 will not scan.
I can Print and copy but I get a "Scan to computer failed" message on the window of the printer.
    Genius:
  • 1,198 Answers
Scanners are moody. Make sure the usb to the printer is plugged into the same port in the computer every time. You may have to uninstall and re-install the printer.
Posted on Nov 24, 2013
  • 6 Answers
SOURCE: My Kodak 5500 won't scan at all and I don't get an error message!
First thing I would do is download the latest software for your printer here:
http://www.kodak.com/global/en/service/downloads/dln_ekn033541.jhtml?pq-path=10624
You can see there is a firmware upgrade however I would avoid that until you exhaust all other options as there is a chance you will brick your printer.
The download is large so make sure you pick the correct operating system for your PC, ie XP, Vista etc.
The grey printing can be solved by going to your printing preferences and adjusting the toner save options. You can also go to the product manuals from this page.
If the download is too large you may want to try using FixMyDriver.com and try the DriverCure application to see if you can update only the scanner driver.
Posted on Mar 06, 2009
SOURCE: Owners manual for kodak 5300 printer
my inks are both full but it will not print out black and the color is faded
Posted on Mar 18, 2009
SOURCE: Kodak esp 5 won't scan to computer
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
Posted on Jun 08, 2009
  • 5471 Answers
SOURCE: My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Posted on Apr 13, 2010
SOURCE: my kodak esp 5250 all in one printer wont print.
Sell It
Posted on Jul 01, 2010
How do I scan to computer?
Sorry For the late answer, but if you want to scan something into you computer in a .png or other format (In windows) click on the start button, and search "Windows Fax And Scan". Once open go to the top left corner and click "New Scan" It opens up a new page, and make sure to select the printer(or scanner) as the one you are using.
Apr 06, 2014 | Kodak ESP Office 2150 All-in-one Printer
Doesn't print but will scan and print
Are you saying it will scan and copy but not print? Copy is a local process and Scan might be a local process (done by the device) Print requires the computer.
I would suggest you get the latest version of the ESP 5 print driver. Then, delete your present driver. Turn the computer off, disconnect the ESP 5 and turn the computer back on. Run the package you downloaded from Kodak and follow the on screen instructions.
This should fix your problem. If not ... let me know ... we can try other things.
Thanks for your visit and please come again.
Feb 03, 2011 | Kodak ESP 5 Printer
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer will copy and print just fine, but it will not scan from the printer or from the computer.
did you recieved error message example 1-2006. If your unable to scan its more On the software and driver issue of you printer., you need to call kodak to properly installed your software and drivers toll free 1 800 421 6699 ext 05.
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Feb 28, 2009 | Kodak ESP 5 Printer
KODAK ESP-3 AiO Will Not Scan On Vista 64 Bit Ulitmate
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
Feb 16, 2009 | Office Equipment & Supplies
Black ink is faded or doesn't print at all
Once installed, Kodak All-in-One printer Home Center software allows you to print, copy, scan, and configure your All-in-One printer from your Windows XP or Vista computer.
To open the Home Center software window on your computer, use the Home Center icon on the Desktop or in the Start Menu
From the All-in-One printer Home Center main menu, selecting one of the six menu items enables you to:
  • Scan pictures and documents
  • Enhance and copy pictures
  • Enhance and print images
  • Configure settings for printing, copying, and scanning from the control panel
  • Access the Kodak Tips and Projects Center Web site.
  • Order supplies from the Kodak Web site.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
172 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
