Fireplace to much air
    Problem Solver:
  • 24 Answers
There should be a damper somewhere in the fireplace.
Posted on Dec 01, 2013
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Fresh air kits
What model of FMI fireplace is this? Is the home a new home that is insulated with a spray foam insulation or anything tighter than regular batt and blow insulation? What part of the country is the house built in? With this information it can be helpful to find a solution for your problem. I work for a fireplace distributor that FMI is one of the lines we carry. Our company has been in the fireplace installation, service, and distribution business for over 35 years. If you give me some more information I might be able to help you find a solution or guide you to the right path. Thanks.
Apr 16, 2014 | FMI Home
Fan working hot air not coming through front vent
One, is there any air at all coming through the top vent? If not schedule a professional service call with a local reputable company. You may have a blockage. If there is air coming through and it is cool, try letting the fireplace warm up for about 15 minutes before trying to run the fan. The fan can only blow hot air after the fireplace gets hot.
Feb 08, 2014 | Heat and Glo GFK-160A Blower Kit for Heat...
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Lack of air to fireplace,need diagram to check air flow from bottom of fireplace in mobile home,
To help you, I will need the correct Model Number of your DESA gas fireplace.
Please advise, thanks.
Jun 02, 2011 | Desa International Wall/Window Air...
Can one use unvented gas logs in a superior CF3860 fireplace?I
Little documentation on this fireplace but it appears to be a vented wood-burner(?) If vented, there should be no problem using gas logs. If burning correctly, you may consider cutting back on the flue and intake air, as moisture build-up is the biggest drawback to gas fireplaces. Too much air is just wasting gas.
Dec 03, 2010 | Heating & Cooling
Black soot on glass and black smoke comes out
Remove the burner and clean all holes ,typically at the end of the burner is a cheep sheet metal valve.This valve adjusts the air to gas mixture by rotating it to increase or decrease the combustible air intake.Air must be sucked into the burner as natural gas is injected into it, this makes for a clean flame,The flame should be blue with small yellow tips.If the flame is long and yellow and sooty increase the air intake on the burner valve.
Jan 26, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Smoke coming in my fireplace
try cracking a window so the vacum sucks the ajr up
Jan 19, 2009 | Vanguard International Blue Flame - Large...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
