Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have a kitchenaid suprba 48, the condenser motor was not working so i installed a new one, but that one is not running either. Any ideas?
    Problem Solver:
  • 11 Answers
Hi Brent, I have experienced the same problem on a few units like yours and it came down to the main control board malfunctioning. It is located next to the compressor behind a metal plate. Those controls are no longer being sold at the part store so, you would have to remove it and send it in for reconditioning. Check out www.corecentricsolutions.com they will repair it for around $109.00 plus shipping. You may be able to find the control on ebay but they are being sold for over $500.00. Good luck.
Posted on Nov 24, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: KSBP25FKSS00 Kitchenaid refrigerator doesnt cool
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 12, 2010
Kitchenaid superba condenser fan not working
Yes, the main board is located in a metal box mounted on the side-wall next to the compressor. Send it in to corecentric or fixyourboard for a re-build. The new board is pricey, and often not available, but the refurbishers have a better warranty than the manufacturer- if your fan is new and has no voltage, the main board is suspect.
Apr 25, 2016 | KitchenAid Refrigerators
On a cpkj 48-1B Goodman heat pump I am having condenser fan issues. runs full spedd for a while then cuts down to barely running, Even after changing the motor and capacitor.
Does the condenser utilise head pressure control to maintain head pressure? if so is the unit fully charged...r22. r410 Freon.If the unit is an older model. the fan motor only runs at 850 r.p.m design flaw. The newer units now run the fan at 1075. R.p.m. I have installed many Goodman split systems and was having problems similar to yours. Hope this. Helps you
Jul 11, 2015 | Goodman Heating & Cooling
I got a true tssu-27 that won't cool what would be the problem with this unit?
Many times the air circulation across the condenser is the problem. Take a look at the condenser and make sure that the condenser fan is running and there isn't dirt or grease blocking air movement. There is also the obvious like a compressor that's not running or an iced up cooling coil. Is the compressor hot? Maybe an additional description would help. Are the fans inside the cabinet running? Good luck hope this helps.
Oct 23, 2014 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
WHAT CAUSED MY CONDENSER FAN TO STOP RUNNING
If the refrigerator is running without any other problems, then just replace the fan motor. Here is the fan and it is only $36.80. No where near $100.00!
Oct 15, 2012 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Control lights ( temperature readings etc ) are consistently blinking on and off, accompanied with a beeping sound
Main control board is over
temperature. Look for blocked condenser air flow or inoperative condenser fan motor.
Refrigerator over 48°F or
freezer over 15°F for 3 hours.
Run diagnostics and test operation of all components.
Both thermistors failed.
Run diagnostics and test thermistors and thermistor leads.
No feedback from evaporator fan
motor. Run diagnostics and test fan motor and/or wiring. The manual is HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2010 | KitchenAid KSSC48QMS Side by Side...
My 685 freezer is fine, but the fridge is only getting upto 50
Check the compressor fan motor. Is it running?
Check the freezer and Fresh food fan motors. Arte they running?
Jan 04, 2010 | Sub-Zero 685/S Stainless Steel Side by...
Kitchenaid Wine Cellar-model # KUWS2246EBLO Power on switch does not turn on cooling compressor. Lite will come on.
Try tapping on the thermostat it is probably sticking.
If it comes on then you will need to replace the thermostat.
Check the start relay on the compressor.
Check the fan motor on the compressor is it running?
Clean lint from underneath on the condensing coil.
Mar 26, 2009 | KitchenAid 48-bottle Wine Cellar
Refrigerator not cooling.
Can you turn the compressor by hand? Did you clean the area around the motors with a vacuum and blown out the armature of the motor? What connects the motor to the compressor? Are there lub ports on the drive motor?
Regards,
Worldvet
Jun 02, 2008 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
48 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
