Question about Holmes Products Humidifiers
Holmes 2060w runs but no water is evaporating
  • 38 Answers
Change the filter and check for fan moving to circulate the air in the unit
Posted on Dec 13, 2013
Refill cap center plunger is broken
I dont see any other way to fix other than purchase another cap...
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
Jan 29, 2014 | Holmes Products Warm Mist HM5700...
I NEED A MANUAL FOR THE HM 2060W
This solution was posted by timbomullet6 and it looks the same
http://www.appliancefactoryparts.com/content/pdfs/116674.pdf
Nov 16, 2013 | Holmes HM2060W Humidifier Filter Wick...
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
I HAVE A HM 5700 HUMIDFIER AND NEED A NEW CAP FOR THE TANK CAN YOU HELP ?
Jan 06, 2011 | Holmes Products Warm Mist HM5700...
My Holmes HM3500 Humidifier is plugged in and full of water. Just replaced filter. Filter has soaked water all the way up to the top of filter. Both lights are lit, but fan is not turning on. I have tried...
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Post comments  for more help or information .........
Good Luck!!
Thanks
Dec 22, 2009 | Holmes Products Cool Mist HM3500...
How do i clean the fan blades on the holmes humidifier
I am assuming a lime buildup from evaporated water. Use vinegar or drip coffee maker cleaner.
Jun 14, 2009 | Holmes Products Cool Mist HM3500...
Wondering if damage to Holmes HM500 humidifier is fixable...?
unfortunately running the unit for too long will permanently ruin the unit. there isn't really a way to fix it. i do deeply apologize for that. so unfortunately you might have to replace the unit.
Nov 22, 2008 | Holmes Products HM500-UC 1 Gallon...
Hm495tg
possibly calcium or other deposits from the type of water you are using in the unit..........
Feb 03, 2008 | Holmes Products Holmes 3 Gallon Cool Mist...
Will not reset
Per the operators manual you have to reset it. 1. Unplug the unit
2. Remove and refill the water tank, being sure to follow the Daily
Maintenance Instructions. Replace the tank onto the base.
3. Wait 5 minutes for the Automatic Shut-Off to reset.
4. After the 5 minutes, plug in the unit and turn the unit on to HIGH
(HI). The RESET light should now be off (if not repeat steps 1 through
3). In about 2-3 minutes, the humidifier will begin to produce
moisture.
Jan 03, 2008 | Holmes Products (048894556579) 4 Gallon...
Humidifiers Logo
90 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
Ben Eng
Level 1 Expert
Tom Chichester
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
