Question about Buffalo Tools AC Delco 3500 Watt Generator
Generator only puts out 10 volts - Buffalo Tools AC Delco 3500 Watt Generator
    Prodigy:
    An expert who has answered 500 questions.
  • Buffalo Tools Expert
  • 573 Answers
Check the rotor rings for cleanliness, they should be shiny, check the brushes and the capacitor, located in the end of the alternator bell housing cover
Posted on Nov 25, 2013
Voltage has gone to ceiling
the generator is spiking the 120 volt plug to commercial voltage bad regulator on the unit more then likely or wired improper
Nov 20, 2015 | Coleman Pm0545003 5000 Watt 10 Hp...
What does a diode stack assmelly do on my
makita g5501r parts Power Generators Questions & Answers
www.fixya.com > Forum > Tags > makita g5501r parts
Power Generators makita g5501r parts questions and answers. ... I own a makita 6100generator and it is only putting out about 105 volts ac and about 208 volts .
Nov 18, 2015 | Makita Electrical Supplies
The generator puts out too many volts. The control knob doesn't help it. Any info appreciated. Thanks, RP
volts on a gen set are controlled by the engine prms
adjust the screw on the governor arm to set at the correct out put volts
remember that unloaded set volts ( rpms ) will drop under load so set about 10 volts over out put voltage so that under load the correct volts will be supplied.
May 05, 2015 | Electrical Supplies
My Multiquip GA6HA generator only puts out 1 volt any ideas for troubleshooting?
Sounds like the alternator has failed, possibly a short or open in the windings. Similar to problem I had with my 10 KW unit. I replaced the alternator.
Jul 05, 2014 | Multiquip GA6HA Recoil Start 6000 Watt...
2003 s-10 changed motor, now won't start. you can
CODE P1637 - GENERATOR L TERMINAL CIRCUIT MALFUNCTION CONDITIONS. CODE P1638 - GENERATOR F TERMINAL CIRCUIT MALFUNCTION CONDITIONS. POSSIBLE CAUSES FAULTY GENERATOR WHICH IS ALTERNATOR.CHECK GENERATOR POWER FEED WIRES AND CHECK GENERATOR VOLTAGE REGULATOR WIRES FOR LOOSENESS AND DAMAGE. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS. IF BATTERY WEAK DUE BAD GENERATOR VECHICLE WONT START.
Sep 23, 2011 | 2003 Chevrolet S-10
My generator is not putting out the proper voltage? it's only putting out approx 75 volts on the 120 volt circit. i adjust the idle to full out and i get approx 112v.
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
Aug 09, 2010 | Northstar Electrical Supplies
I chek the volts on the batery and is only 10 and i do chek the generator and is only 9 volts have to change the generator
charge the battery real good and start the bike rev it up to 3000-5000 rpms and see what kind of volts you have if its over 13 your good if not have the generator checked you might get lucky and only have to replace the rectifier in the generator
May 15, 2009 | 2003 kawasaki ZX-6R
Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Feb 07, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Generator 4600 series
Starts Generating 120 volts and whitin 30 seconds is putting out 0 volts, and the generator has high speed
Feb 19, 2008 | RIM BlackBerry Pearl 8100
Buffalo Tools AC Delco 3500 Watt Generator Logo
81 people viewed this question
Top Buffalo Tools Electrical Supplies Experts
Bill Boyd
Lawrence Oravetz
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
