Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheem 101 not reheating after power outage fuse is ok
  • Rheem Master
  • 5,245 Answers
Posted on Nov 24, 2013
Blowing fuses on rheem rtgh 84dv
Call service technician
Check polarity of 120 volt outlet
Call Rheem for new PC board
If the 3A glass fuse located on PC board is blowing, then something is drawing too much current or shorted on board... problem is probably bad PC board
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Oct 12, 2014 | Rheem RTGH-84DVN Indoor Direct Vent...
No power, no lights
Check your water pressure, it should be 1.5 bar approx. The unit will just look at you as the flow switch will prevent operation due to lack of pressure.
Sep 28, 2013 | Rheem Water Heaters
Rheem power vent 2 flashes red led twice
Copy following link to identify gas control valve and download error code information by type of gas control, and possible service manual.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
If you have Honeywell gas control, then 2 flashes with three second interval can mean pressure switch has failed. And or related issues.
Scroll up on same page to find pressure switch heading among the troubleshoot links.
Or use Ctrl+F find feature on browser, and word search page for 'pressure'
Same page also has Rheem parts list 2010 so you can locate exact part number using model number that shows on label on side of tank.
Rheem does not post service manuals, but other companies do, and they can apply to Rheem (except for the FV system, which varies by manufacturer)
Best that you save product manual when possible because it will have important information including, parts warranty, error codes and parts list. Plus routine recommended maintenance that can prevent outages and error codes
Sep 06, 2012 | Rheem Water Heaters
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
Noisy Rheem 16 instant hot water heater
About the only device in that heater that could cause the noise you describe is an electrically operated valve that controls water flow. Rheem is a better-than-average company so I would give them a call and describe your problem to them; I'll bet that they will be glad to tell you which part you need and supply it to you.
We had a heat pump system from Rheem that needed only the replacement of one large relay and the outside unit fan motor during more than 25 years of service and is still operating at age 30 in our former home.
Oct 03, 2009 | Rheem 81VP6S/430126 Water Heater
Power outage caused c8 / 76 error - No Hot Water
How old is your unit...if less than 5 years old tell Polam/Rheem customer support you are recieving a code 76 error - this is a loss of communication between the remote and the burner control assembly. Part will be covered under MF defect warranty. However, the part is covered....the labor to install is not.
If you are slightly technical you can install the part yourself...customer support will walk you through the process and they give you a step-by-step procedure to follow.
Sep 24, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
218 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
