Motor wont start is new motor
SOURCE: I put it "up" for
push it forward before trying to pull knob and make sure the incline is at the lowest level.
SOURCE: How do you put the treadmill down?
There is a knob on the support bar behind the treadbelt deck. Give the deck a little push up, then pull the knob out and lower it.
SOURCE: treadmill powers up but belt will not rotate
Check to see if the motor is spinning. If not spinning, then use a voltmeter to find out the voltage of power going to the motor that spins the belt. See if you can rotate it by hand.
SOURCE: I left the red key in epic view 550 for 1 full
Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch to the reset position.
