Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Hi my Kenmore Oven Model # C970-505321 is not working anymore.
I was reheating something and I heard a pop, wasn't sure what it was until the day after when trying my oven. The top burners work, as well as the clock and other functions. As soon as I press for bake it goes to preheat...Help!
  • 5 Answers
Maybe your bake element burnt out
Posted on Nov 24, 2013
  • Bernadette Garand
    Bernadette Garand Nov 24, 2013
    Broil doesn't work either, and it's not a gas stove, it's electric.
  • mikadot
    mikadot Nov 24, 2013
    It sounds like it blew a hole in the element. Only by using a continuity tester can you trace where the problem is, unless you can see physical damage
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
  • 1214 Answers
SOURCE: Kenmore model 95032 - buy new or get repairs?
I would say buy a new one if you can get a replacement for $399.00.
You can get an idea of parts costs by going to SearPartsDirect.com and entering your model number. I would think the element would be about $25.00, and the top would probably be another $150.00. Add in labor, and your quickly over $200.
I would do the same thing if I didn't know how to work on them.
Posted on Jan 24, 2009
  • 574 Answers
SOURCE: electric oven will not heat
look at the elements where they connect inside at the back and see ifthe connection looks burnt if it does take out the element and check continuity or ohms if you have continuity throughout the element then the connection may have grounded against the frame of the oven. You will have to pull oven out to check that though. Hope that helps.
Posted on Aug 24, 2009
RED92JEEPER
  • 51 Answers
SOURCE: Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Posted on Oct 01, 2009
kirkx
  • 2019 Answers
SOURCE: Oven will not heat
Since bake and broil use different elements, and it is unlikely both went out at once, and then I would suspect the switch instead of the elements.
Posted on Sep 06, 2010
I was cooking dinner. Was using Kenmore oven on Broil and heard a loud pop. Everything went dead. Is my oven dead? Can it be fixed and how much would it cost? Would it be better to buy a new oven?
they dont make em like they used to anymore.. be looking under the top for a burnt wire somewhere..if the burners still work its ok if they dont. check your fusebox.. see if a fuse blew..
Mar 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven 317b6034
It sounds like the heating element is faulty. If it has a short, it will have a damaged place. A short causes a build up of amps until it can't take anymore and then a action will happen like a fuse blowing, which it the noise you hear. You can get replacement elements on Amazon fairly cheap. To fix, unplug the stove. Lift and tug on the element to pull it out of the socket. It is usually easy.
Rich Long
Jan 26, 2014 | Kenmore Ovens
Popping noise, flames between oven and wall and burning plastic smell from Kenmore gas oven. We had noticed the smell off and on for 2 months, but the oven still worked properly until last night. I...
sounds like the insulation on the cord has been worn through and is shorting out. turn off the breaker pull out the oven and look where the cord goes into the oven and look for black burn marks.
Apr 09, 2017 | Kenmore Ovens
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
My ge model hvm1750 just stopped running while it was reheating something. Nothing works. Home circuit is ok
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Apr 20, 2011 | GE Microwave Ovens
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Evaporative-coil-Parts/Model-867813350/0582/1610510/00007536/00001
Ray
Jan 19, 2011 | Kenmore 94210 / 94211 / 94212 / 94214 /...
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
While oven was on, heard loud pop. oven no longer
Sounds like your element wire shorted out on back of unit.Try removing back panel and cheak wire on bake element .MAKE SURE YOU UNPLUG OR TURN OFF BREAKER.Hope this helped you out:)
Mar 11, 2010 | Kenmore Kitchen Ranges
Pop pop Kenmore hood microwave 665.60652 - year 2002
hmmmm, i wonder if you have a gear or something similiar to this going out. (turn tables)
If not, something tells me you have a component that is arching inside of your micrwave. I would call someone to double check to make sure it is ok.
You will be surprised at how many people wait until it is too late to service their units, when it goes out, it is gone.
good luck
May 25, 2008 | Kenmore 62702 Microwave Oven
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
110 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
