Question about Arris SURFboard SBG900 (49402201900) Modem
SBG900 goes off for every 10 Mins
Hi, This seems a bit strange, when I try to browse different sites parallely my modem break off and gives me limited or no connectivity, I checked with my ISP and he has asked me to change the modem. It is more than one year that I bought this modem with wifi. Can anyone please suggest me what to do with this. Very annoying, everytime I have to reset the modem. If I just dont browse it multi pages it works fine.
  • 82 Answers
Dear check another modem on your pc if the problam is same then something wrong in your pc other wise 100% you will have to change your modem
Posted on Oct 10, 2007
SOURCE:
How do i turn wifi off surboard sbg6580
log in to the modem as if you were going to change the wireless password (browse to default gateway and enter username and password) then turn off SSID broadcast (usually by un-checking a box)
try these
SBG900 Default IP:
192.168.0.1
SBG900 Default Password:
motorola
SBG900 Default Username:
admin
Nov 19, 2013 | Arris SURFboard SBG900 Wireless Router...
Lost the stick on back of modeme try find MAC ID for SBG900
Open up a command line prompt (Start>Run>cmd
At the command (C:\) type the following: arp -a
That should give you the IP Address and Physical (MAC) address of your router.
Good Luck
James
Apr 17, 2011 | Arris SURFboard SBG900 (49402201900) Modem
Cant login to my sbg900, using admin for login but not recognising password
Try resetting the router. You can find a small hole with a button inside it at the back of the modem. Use a pin or a paperclip to press it for 5-10 seconds so that it will be restored to the factory settings.
Hope this helps! :D
Sep 08, 2010 | Arris SURFboard SBG900 (49402201900) Modem
I am unable to connect to my VPN, although my wireless connection is excellent
Double check that you are using the proper WEP key and VPN settings. You can also try using a different channel for your wireless. Many of these systems use Channel 6 as the default channel. Change this to channel 10 in the router. If you are forcing 105mbs you will need to change that to automatic to make this change as in forced 105 mode the only broadcast channel to use if 6.
Oct 10, 2009 | Arris SURFboard SBG900 (49402201900) Modem
SBG900 doesn't go online
I have the same modem/router. I had the same problem. I had to call my service provider and they had to put the modem into the system so the ip address would so up correctly. You need to call them and tell them what kind of modem you have. Have the model number and serial number ready to give them. They will have to make some adjustments on their end and they will most likely tell you to reset your modem. After that it should work fine. My worked fine after I talked to them and they made their adjustments. I hope this helps you.
Jan 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Vonage ip voice will not work with internal firewall turned on
then iot seems that your fire wall is not compatible with it, try installing a different one, or try port forwarding that will fix your problem
Aug 15, 2008 | Arris SURFboard SBG900 Wireless Router...
Port help
You can get the message even if you have the ports open. As long as the patch is downloading just ignore it. it may sit in the same spot for a bit but its still transferring. I've never noticed a difference in speed. It will take quite a while for a new install to patch. I'd leave it for a few hours.
May 27, 2008 | Arris SURFboard SBG900 802.11g/b...
I get connected to my work VPN, but i can't sea any servers.
Because when you want to browse free it will happen, so better check with he hotel/fastfood or airport IT admin, he would have blocked it.
Good Luck
Johnson
Dec 10, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Moto Surfboard SBG900 and VPN Client = SLOW
Please see the specicification, also check with you company
IT Admin, to release it to the Max speed or to check the
net work cable, may be too long, also Test the cable with a Data Test meter and conform the data quality. Or change the port from main router.
Otherwise change the whole networking router.
Regards
Nov 15, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 (49402201900) Modem Logo
180 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
