Question about Sony Televison & Video
My CECHYA-0081 Will not connect
Won't connect to the PS3 when plugged in. It is the USB part, and when I plug it in, the light will not come on, and it won't appear on the list. PLEASE PLEASE HELP
  • 5 Answers
SOURCE: netgear won`t connect to ps3
He needs to go to a local best buy radio shack, office depot type store and get a cat-5 ethernet cable from his ps3 to his router, this will solve all his problems since wireless gaming always has drop spots that can get worse depending on the router type. Also if their are other computers make sure there not downloading or eating up bandwidth, this will not allow it to connet. Make sure the router settings allow the ps3 to connect, does the ps3 see the router but wont connect? you need the wep key.
Posted on Jul 08, 2009
domotek
  • 591 Answers
SOURCE: Hi my tv fell off
After a fall like this (even on carpet) it probably has a cracked circuit board or a loose connector, first (since you took it apart any way) look for all connectors, than unplug them and re-plug them to make sure all plugs and boards are seated correctly, if you still don't have luck, than take out all the circuit boards and check them for cracks under a good lamp and magnifying lens, than repair the cracked traces with a good soldering gun by scratching off the varnish coating and applying solder. (if the crack is to wide you can solder a peace of coper wire to the trace on the board)
Have fun!
Posted on Jun 25, 2011
Testimonial: "Thank you for the response what circuit board the power board? I I was to change that out how would I make it safe not to shock me "
SOURCE: kodak easyshare m550 won't turn
This is happening to mine as well. I don't know what to do!
Posted on Jun 26, 2011
Geekman
  • 32281 Answers
SOURCE: My onxy mp3 player won't
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Jul 13, 2011
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Posted on Jul 16, 2011
Cechya-0081
Hello there,
I lost my CECHYA-0081 wireless adaptor driver for windows XP, anyone could kindly send me a copy or link to me at Frank_qiao@hotmail.com? With lots of thanks!
Mar 25, 2014 | Sony UWABR100 Network adapter USB ...
Why won't my band hero guitar work
Do you have the usb plug in that goes with the guitar?
Jan 21, 2013 | Activision Band Hero for PS3
Hi I just moved plugged in my ps3 the red standby light came on and now nothing it won't even try to turn on what should I do ?
Sorry I had no idea you sent me this message until today. I apologize for the delay. You probably found a solution by now but if you haven't, please try this..
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming.
I hope this helps :D
Oct 24, 2011 | Sony Playstation 3 (PS3) Console
Can't connect orb controller to ps3
Plug the dongle in to the USB port, turn on the PS3 and the LED will flash a lot (as if you've pressed the connect button), then press L3 and SELECT together for 3 seconds; it'll then connect. Then press the PS button.
As long as you keep the dongle plugged in, the controller will not disconnect and won't need pairing again.
Jul 27, 2011 | Intec PlayStation 3 Turbo Shock III...
Controller won't link to the ps3 middle button just flashes as if its trying to connect. I have connected the tab coors but still nothing works.
Is the controller completely charged? If it is, then try this
1) Manually turn on your PS3 using the power button on the PS3.
2) Take your USB charger for your controller and plug it into the USB port. (Do NOT turn on your controller yet!)
3) Plug the controller into the charger that is connected to the PS3 USB port.
4) Now turn on your controller using the middle "PS" button.
The lights will flash for a few seconds, and that will sync your controller to that particular PS3 system. This might help :D
Jun 20, 2011 | Video Game Consoles & Games
When i try to download something it says connect storage media to save destination what does that mean and what can i do to download stuff without that coming up
File formats that the PS3 doesn't recognize as something that it can play, can only be saved to a USB storage device, or a memory card. You can't download anything to the PS3 hard drive via the browser that you couldn't copy to it from a USB storage device. That is what the error message means. You have to connect an external storage device, because the PS3 won't store this file format on the internal drive. This protects the integrity of the system. If you connect a USB drive or memory card (you will need a USB adapter for the memory card if you don't have a launch PS3), then you can download anything that you want using the PS3 web browser. Sometimes called a thumb drive, a USB drive costs about $20 and plugs into the USB slot and is removable.
May 01, 2011 | Sony Playstation 3 (PS3) Console
My ps3 band hero drum kit will not sync the light on the dongler that is plugged into the ps3 doesnt light up
When you plug the wireless receiver into the USB port on the ps3 it should light up. Press the PS button on the drums and it should connect. If not then the receiver must be broken
Jun 01, 2010 | Activision Band Hero for PS3
Its a big ben wireless controller with no usb how do i connect it to my ps3
plug the usb thingy in the pc then connect the bigben controller then take out usb thing plug it into ps3 conct the controller and itz done
Jan 18, 2010 | Sony Wireless Controller for PS3
Ps3 controller
Turn your ps3 on and plug in your controller with the usb cable provided with the ps3 and then press the ps button while it is plugged in and it will connect. Then unplug the controller and it should wirelessly connect.
Jun 14, 2009 | Sony Wireless Controller for PS3
Instuctions connecting ps3 to hd ready tv
The answer is simple really. You can't connect your PS3 to your TV with a USB cable. You need an HDMI cable.
Aug 11, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
