Question about Emerson EWD2203 DVD Player/VCR
Can't get the player to eject the cd
It was playing and stopped. We tried to remove the CD but can't get it to open
4 Suggested Answers
SOURCE: "NO"
I have th4e same problem, has anyone solved this "No" screen problem and fixed the CD player on this unit?
Posted on Feb 04, 2008
SOURCE: Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Posted on Feb 24, 2008
SOURCE: CD player stops, won't open
there is a spring loaded mechanical switch under the cd rack that often breaks
I am trying to fix one right now and i am going to rig a three phase switch on the out side of the case
Posted on May 16, 2008
CD Changer does not eject and I can not remove the cartridge.
IVE HAD SUCCESS WITH REPLACING/REPAIRING THE DRIVE GEAR/BAND WHICH OPENS/CLOSES UNIT..?
Dec 31, 2014 | M&S Systems MCD-6 6-Disc CD Changer
CD player won't accept or eject CD in 2004 Colorado truck
sounds like a perished rubber off one of its wheels inside.
Jun 20, 2017 | 2004 Chevrolet Colorado
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
When playing a CD, it will stop and cease playing. It takes along time to eject the CD
the cd player eye is dirty try cleaning if no good it needs to be repaired internally
Aug 29, 2012 | 2008 Toyota Yaris
OEM CD player is stuck
have you tried disconnecting the battery cables? if this does not work, a CD may be stuck in it! You will have to remove the changer and open it up to remove the cd!
Aug 15, 2012 | 2005 Chevrolet Equinox
Inserted cd disc. play music on cd but will not eject the disc cd is stuck in cd player
Mostly The cd is jammed between the laser sensor and the cd rotator.Try removing the audio player and reseting the whole device if possible.Or if you have sufficient technical know how.Open the player try to manually open the disc tray.and remove thedisc.This can happen even  if the disc is broken inside the player.
Sep 28, 2009 | 2004 Jeep Grand Cherokee
CD stuck in CD Player - 1998 Mazda Protege
It might be a Bose system. I usually remove stuck CD's by grasping the edge with a pair of tweezers and pulling slowly, there will be some resistance. Try to reset first by removing the fuse for about 30 seconds and after it powers up again (don't turn it on yet) push the eject button.
Apr 11, 2009 | Car Audio & Video
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
Cd ejection
Look for a tiny, recessed Reset button on the front of the unit with the face removed. Press this button with a pen tip; it should spit out the CD and work correctly afterwards. This will also erase your station presets and audio settings.
Mar 13, 2007 | JVC KD-SX770 CD Player
Emerson EWD2203 DVD Player/VCR Logo
32 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
