Question about Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System
Sony dav-hdx265- disc is stuck- door will not open
Cannot eject nor play disc. Problem code c3100 problem code comes up. Unplugged system, nothing but system trying to change discs or eject
    Novelist:
  • 126 Answers
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Posted on Nov 24, 2013
SOURCE: Sony BRAVIA DAV-HDX265 Changing the region code
buy a region free player :)
Posted on Mar 17, 2008
IB4G2008
  • 3587 Answers
SOURCE: sony home theatre model dav-hdx265
hmmm..didn't know you could do that? Do you have the user manual on hand?
Posted on May 28, 2008
SOURCE: Sony DAV-IS10 Error Code C 13 71
I had the same problem, took my system to the service centre - they replaced the lens and it works fine now. They charged me Rs 1000 (About 25 USD)
Posted on Feb 16, 2009
SOURCE: Disc stuck in homethreatre system
you can try gently to get the disc,s towards the front of the player by turning it upside down ,then you can also try pluging it in and trying to gently pry the door open with the assist of the open button , if that does not work within a reasonalble amount of time you cac also take the casing off and reve the dvd,s that way ,just lay out the parts in order so you remember where they came from , hope i was able to help you , it happened to me already and once i had no choice but to take it appart and another time i was able to get them back into the vicinity of the inside tray and was able to open it that way , either way you choosae good luck and thank you for letting me hopefully help you Sincerely Glenn mayer
Posted on Mar 05, 2009
tc3gs400
  • 14 Answers
SOURCE: how to play multi region disc in sony hometheatre dav-dz280
your player comes as a multi reader player..
Posted on Jan 12, 2010
Dav-hdx665 only plays certain DVDs, why.
Check the region code. Or the laser beamer is dying.
May 07, 2014 | Sony Dvd Home Theater Remote Control...
Some how i accidentally child locked my Sony DAV-HDX265. how do i unlock it.
  • AH, well lets fix that.
  1. Press "System Menu"
  2. Press the Up arreo ^ or dowm arrow v repeatedly until "CHILD LOCK" appears.
  3. Press ^ or v to select a setting for "OFF" or "ON."
  4. Now press the "+" button and the setting is changed to your selection.
  5. Press "SYSTEM MENU" again to exit.
  • To remove a disk while child lock is on
  1. Press the "eject button" on the remote and press "DISK SKIP" repeatedly until the desired DISK indicator [1-5] lights up.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Sep 26, 2011 | Sony Bravia DAV-HDX265 Theater System
Child Lock Sony DAV-HDX265
  2. Press the Up arrow ^ or dowm arrow v repeatedly until "CHILD LOCK" appears.
Regards,Tony
DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Aug 28, 2008 | Audio Players & Recorders
Jul 31, 2008 | Sony DAV-IS10 System
Sony DAV-HDX265 Surround Sound
1st of all, unplug the set. Open top cover of unit and go to Optical Lens. Push it outward and inward for 2-3 times. Place top cover back. Hope problem will be solved.
May 30, 2008 | Sony DAVHDX265 System
Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Jun 09, 2007 | Sony DAV-FR10W System
Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
225 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
