How top remove dash panel on vt commodore to access fan
  • 7 Answers
SOURCE: vt commodore
Yes what problem do you have?
Posted on Oct 04, 2008
  • 37 Answers
SOURCE: Removal of Dash to Access Noisy Fan
BE PREPARED FOR ALOT OF WORK IF YOU ARE TO REMOVE THE DASH. FAN UNIT ITSELF IS NOT THAT DIFFICULT IT IS LOCATED PASSENGER LOWER SIDE BEHIND GLOVE BOX. CHECK TO SEE IF YOU CAN SEE YOUR EVAPORATOR THROUGH YOUR CABIN FILTER WHICH IS UNDER HOOD NEAR WINDSHIELD PASSENGER SIDE.
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: exploded diagram of a vt commodore
tapets very noisy in vt commadoor is it the oil pump
Posted on Jun 27, 2009
etirbynnor
  • 655 Answers
SOURCE: VT Commodore 6x9 Speaker install
Hello taz_is_1,
Sure, it's OK as long as the new 6X9's are the same impedance as the door speakers.
Unless there are already wires and cutouts for rear shelf speakers, the installation will be pretty involved. And while I'm not sure of the Holden product, it's sister versions, Chevy Lumina and Omega, does not have such cutouts or wiring.
Wires going into the door interior for window controls, locks, and speakers will all be in a bundle and go from the vehicle frame into the door through a flexible rubber connector with grommets on both sides. You'll need to run your wires from the disconnected door speakers back through the same grommets to avoid pinching and damaging them. After you get them back into the vehicle interior, you can run them under the trim or carpet to the trunk area under the rear shelf. If you have never done such work before, I recommend you get someone who has to help you. You'll need to make an appropriately sized cutout to mount the 6X9's. And depending on the material, you may need some kind of reinforcement and/or spacers. Also, look out for anything underneath the trunk lid that may come into contact with the speakers. There's usually 2 metal rods than span the width of the trunk and run almost directly under the shelf. They will have to clear the speakers in order for the trunk to open and close properly.
It's more work than a simple speaker exchange with a good pair of aftermarket speakers. And the benefit is minimal. A really good set of 5 1/4, 6 1/2, or 6 3/4 Alpines, Bostons, or Infinitys will sound better than a mediocre set of 6X9's any day and you don't have to cut everything up to install them in most door openings.
Hope this helps.
Posted on Sep 11, 2009
Testimonial: "Hey thanks for your reply... You are probably right about just swapping the old 6 1/2's for new ones. i'll just leave those 6x9's in my ute. Cheers"
SOURCE: Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Posted on Jan 31, 2010
HOLDEN COMMODORE VT HEADLIGHT FAULT
check out a faulty headlight switch
May 01, 2017 | Holden Cars & Trucks
Step by step method on how to put fan belt back on commodore 98
Hi Sharon, The link below is a diagram of pictures for 1998 VT commodore fan belt.........CHEERS MATE..
how to put fan belt back on commodore 98 Google Search
Apr 15, 2016 | 1998 Holden VT Commodore
On my vt commodore the dash lights come on ABS,CHECK ENGINE,OIL LIGHT,TRAC OFF,
check for loose /dirty battery terminals. Have a load test done on the battery top check for faulty cells/ridge.. Check for faulty ignition switch
Jul 30, 2014 | 1999 Holden VT
1989 holden VT commodore a/c fan not starting at all
try swapping relay under bonnet with same sort
Mar 14, 2013 | 1998 Holden VT Commodore
Horn not working in vt commodore how to get to it?
hi it will be the wiar behind the stering wheel you got to take it off to get to the wiar to fix it
Jan 16, 2013 | 1998 Holden VT Commodore
Blower fan in vt commodore not functioning but a/c light on
check the blower fuse, there are most likely in 1 of these 2 places.. The kick panel by the driver side or the fuse box under the hood, I'm attaching a you tube video to help you check the fuses and find the one by the kick panel,
Dec 30, 2012 | 1998 Holden VT Commodore
Vt commodore fuel wiring
I am sorry but we do not have wiring diagrams here at fixya. You may be able to access them HERE
Oct 03, 2012 | 1998 Holden VT Commodore
Can you tell me what the symbol on dash is 'far left' please? vt holden commodore 1999
I am not familiar with your vehicle, Ive never heard of it. However a lightning bolt symbol would probably indicate a problem with your electrical system, possibly the battery or alternator.
Sep 20, 2012 | 1998 Holden VT Commodore
12 people viewed this question
 Grubhead
Grubhead
