Question about Canon DC100 DVD Camcorder
Fuse blown. No power at camera
Can not turn on the camera/charge the camera. Cannon Australia have replaced the fuse. It then worked for a while, however the problem has returned. The fuse is a VD7-2241-001. How and where is this replaced? Thank you
How do you reset a Cannon Power Shot A560 camera
Lens errors are usually caused when there is something interfering with the extension mechanism , or your camera been dropped with the lens extended, or your batteries ran down . try the ff. procedures hope this helps
  • replace a fully charged batteries / battery pack
  • check out this link
Do It Yourself Digital Camera Repair
Aug 27, 2014 | Cannon Cameras
Camera still dead with a new charged battery. Is it possible to overcharge a battery so it won't work?
If you have another battery definitely give it a try, most likely it won't work either. The problem is probably the fuse located on the DC/DC board that has 'blown' causing there to be no power. Replace the board and the camera should work fine. Canon will probably charge $175 or so for the repair.
Hope this helps.
Thomas
Sep 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I have a Cannon iP1500 printer and all of a sudden it will not turn on. It is as if there is no power. I checked the cables and they are plugged in. What might be my trouble? Could it be the cables or...
Unfortunatly a multi-meter is needed to test the cable, although many appliances around the home have a similar plug on the end that will work as a test.
If the power cable does not fix it then a fuse inside the printer has blown. its a $2 part that a technician charges $100 to install !!!. If a power cable does not work then unfortunately buy another printer.
Jan 27, 2010 | Office Equipment & Supplies
Cannon Digital Rebel xt died will not turn on , recharged nothing
I think you have a faulty fuse (there are three in total) inside the camera. The fuse might have blown because of bent pin for the memory cards or a faulty cf card. In wich case, you have to repair it yourself, there are pages on the web that describe what you have to do (search for fuse and 350d), or send it to a canon service center ( they will change the complete motherboard because the fuses are soldered to the mainboard and they won't change them)
Sorry budddy
Jan 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera has just stopped working, will not turn on but is fully charged
YOUR CAMERA CPOUOLD HAVE A BLOWN FUSE ON THE DC/DC CONVERTER BOARD IN THE CAMERA OR THE BATTERY COULD BE BAD EVER AFTER YOU CHARGED IT .
Nov 28, 2008 | Cameras
CANNON SD750
send it to us most likey it is a blown fuse. we can repair for 85.00 worst case 125.00 depending on the issue. but 125.00 is the very worst case normally it is only 85.00 send it in for a free diagnosis.
Jun 26, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Fuse Blowing Repeatedly
if you are not a tech have one check your tv,the voltage regulator is shorted and needs to be replace.this component can be found in the power supply.i do not have the part number and location as i have no schematic for this set.
good luck
May 03, 2008 | Televison & Video
Cannon 750i mini digital camcorder
I am unable to record a video or take a picture with my MV750i Mini DV. I allways get a black screen.
Could I have any help?
Joaquim
Apr 15, 2008 | Canon MV750i Mini DV Digital Camcorder
Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
eNDi
Oct 17, 2007 | Canon PowerShot S45 Digital Camera
Cant turn on
This is generally caused by a blown fuse. These powershot models have an excellent power protection system and will blow a fuse before damaging any critical parts in the camera. At some point the camera experienced a power surge (static electricity, short, etc) and the fuse blew. Chances are good that the camera is still just fine, but will require a fuse replacement. The charge for this at my shop is $89 plus the fuse which is a few dollars. It can be replaced by someone technically inclined who has a pair of tweezers, the proper fuse, and a soldering iron.
Jun 06, 2007 | Canon PowerShot SD600 Digital Camera
Canon DC100 DVD Camcorder Logo
66 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
