Sony Bravia (52 in.) Screen not working
My 52" Sony Bravia HD TV's screen is currently not working properly. Sometimes when I turn it on the screen turns on but is completely black and doesn't work, other times when I turn it on the screen works but the bottom half is completely blurred and there are lines running through it and is not clear or visible. I was wondering what the source of the problem might be, or how much it would cost to replace the LCD? Any help would be appreciated, if you need more information, please reply.
  • Televison & ... Master
  • 17,326 Answers
It is not the LCD screen that is bad. It is a problem with one of the control boards. What is the model number?
Posted on Nov 24, 2013
SOURCE: Replacing LCD TV screen
crack on the screan of 32 inch plasma
Posted on Dec 04, 2009
  • 84 Answers
SOURCE: Sony Bravia XBR4 52inch LCD cracked
It can be replaced, but it is probably going to cost you more then the cost of a new TV to do it.
Read the tech tip I wrote on this very subject.
http://www.fixya.com/support/r3831376-when_cracked_lcd_led_or_plasma_tv
Posted on Jan 07, 2010
SOURCE: 3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Posted on Jan 21, 2010
budmrtn
  • 11361 Answers
SOURCE: Sony Bravia LCD black shadow screen
You may ahev failing T-CON board, try having a small fan blowing at the vent on the back of the TV. If you can post pictures it will help a lot.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 29, 2010
ahmosea
  • 47 Answers
SOURCE: When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
Posted on Jul 23, 2010
Sony 52xbr4 screen flickering
Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a Sony KDL - 52W4100...the picture has been awesome for two years but recently i am now getting a steady stream of horizontal lines and at top screen red and green boxes and sometimes bleeding of...
meder tv service......this can sometimes be due to t-controller board failingnot sending proper data to panel.....can order on shopjimmy.com or partstore.com....happy repairs....
Feb 25, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How do I return to a ``Normal`` HD screen from ``Partial Zoom``? Bill
Look for a button on the remote said like ASPECT RATIO,VIEWMODES.PICTURES.Pushes one of these bottons pick the picture that fit ur tv screen.
Jan 15, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Sony Bravia 52" tv and the screen was hit
Not likely take to a qualified repair center. It will need a new screen
Nov 28, 2010 | Sony KDL-52XBR4 LCD Monitor
We need our Sony 52W4100 Bravia screen replaced. What is the cost?
Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV
Part # 1-802-791-12, cost approx $2,251.54 + core
Parts reference: Andrews electronics, 800 289 0300.
May 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
When we turn on our tv in the morning the left
Call Sony my friend. I have the same exact issue with the same model. They already have a recall for the 46"XBR4. Let Sony know that us 52" owners are having the same issue. I'm essentially calling them everyday until they fix it.
Mar 27, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a Bravia 52 in HD LCD TV. My problem is that when i turn on the television, the sound does not come on. I have to turn off the TV then turn it back on again to get sound. Why is that?
Not sure, but there is firmware update for this model posted at Sony to adress some A/V issues for this model.
Go to the site and follow "support" links to read specically what issue it addresses.
Chat live online with tech help too if this doesn't help.
Jan 05, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia LCD tv screen is broken
i have the same set and the screen is cracked on it, i checked and the screen is $1050.00 so i believe its not worth fixing
Jul 22, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Televison & Video Logo
Top Televison & Video Experts
