Question about Insignia Televison & Video
Hi, I have an Insignia 50 in plasma television that all of a sudden went to nothing but vertical lines, then popped a cuople of times and went black. Sound is still ok.Enybody have an answer for me as to what went wrong.
    Problem Solver:
  • 6 Answers
This is a buffer issue.
do the line go through the menu if you display the menu when the lines are visible?
do the lines go from the top to the bottom of the screen or stop halfway there?
do the lines change colors?
if the lines go over the menu and all the way down to the bottom of the screen, then its a buffer issue, top and bottom buffer.
hopefully it's just halfway then you only have to replace the top buffer, less money to spend.
Posted on Nov 24, 2013
  • 179 Answers
SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
Posted on Nov 28, 2007
  • 18 Answers
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Posted on May 31, 2008
SOURCE: No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Posted on Sep 28, 2008
SOURCE: LG 50PX4DR plasma tv
I had the same exact problem as posted above. My 50" LG plasma was out of warranty for 1 year! I called the LG executive call center, and they were very helpful. They offered to pay for the parts and labor. They recommended a few local repair shops, and they set everything up for me. The tech came out within 4 days with one part. The tech had to come out one more time the following week, since more parts were needed for the repair. The Y sustain board, along with 2 adjacent parts that are required to be replaced as a set, and the power supply had to be replaced (parts alone cost just over $900). TV is like new again; I'm very happy with how LG handled it, and made what could have been a bad experience a good one.
Posted on Apr 30, 2009
  • 380 Answers
SOURCE: solid black vertical line
You could have one of three problems. One is really expensive to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went bad. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable2_bing.gif and clean it off a bit and put it back. If its still there, you have a deeper problem.
The buffer boards are located across the bottow when you take the back off. About 3 inches wide. Sometimes they are on the top as well.
Posted on Dec 06, 2009
My 50 plasma tv has vertical lines running from top to bottom on left hand side of screen. What can I do to fix this?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 05, 2016 | Insignia Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
I have a 50" plasma insignia and it has colorful vertical lines down the middle.
Lines can be caused by a number or things: bad main board (control) which is rare, bad or loose plugs or solder connections.
The worst case is the issue (connections etc) can also be inside the display panel (PDP or plasma display panel) where they cannot be got at.
Parts for brand listed are not real easy to find in some cases.
Nov 05, 2012 | Insignia 50 in. Flat-Panel Plasma HDTV
My NEC LCD monitor suddenly starts 'weeping' and I get vertical black and white lines from the left up to middle of the screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem....
Jun 15, 2011 | NEC 50XR5 50 in. HDTV Plasma Television
Insignia ns-pdp50 plasma. pop of death, audio but no video
I suspect that your supply has gone bad. You will need to find the service manual for voltage measurements. If you want to get replacement boards many can be found on ebay or you can check www.shopjimmy.com they stock boards for many units and I have had no problems.
May 04, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
I have a 8 in. black line going top to bottom left 50 in.insignia
I would recommend scheduling a technician for diagnostic and repairs. In-home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 15, 2010 | Insignia 50 in. Flat-Panel Plasma HDTV
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
TV went black - Please wait message...
I think you both have faults on the line output stage of your tv either the line output transistor has become faulty or the line output transformer itself has become faulty. If you are able to check this for yourself otherwise find a competant technician. Hope this helps.
Aug 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
Nov 27, 2007 | Toshiba 50HP95 50 in. Plasma Television
Televison & Video Logo
73 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
