Toshiba pairing code
I want to connect my phone to the tv. they ask me a pairing code that I do not know where to find
  • 3 Answers
Try to use a standard key like "0000" or "1234" for many BT device work fine, like BT headset
Posted on Nov 24, 2013
Need Toshiba TV code to pair with my phone
standard code is 1234 or 0000 can be 4321. but its usually the code from the phone trying to pair with the tv should show up on tv screen.
Apr 04, 2016 | Toshiba Cell Phones
Pairing codes for bluetooth
When you are pairing two devices (your phone with another phone, or your phone with a computer for instance) with bluetooth, you may be asked to enter a code. This ensures that someone random can't connect with your phone without your knowing about it or giving permission. Depending on the two devices, one device may automatically provide a random code, which you then enter into the other device. Other systems ask you to enter a code. Just make one up, any code will do. Just be sure you enter the same one on both devices! Best of luck!
Aug 11, 2014 | Kyocera Cell Phones
Toshiba tv what is a pairin coad
A Pairing Code is generated by the originating device which must then be typed into the second device in order to protect security of devices. Usually a xxxx 4 digit number is used. It appears on the first device when setting up the Bluetooth connect for the first time.
The Bluetooth is put in discovery mode & then creates a random Pair Code when it discovers another connectible device.
eg. You use Bluetooth headphones to Pair with your iPhone. The code is usually 0000 for simple devices.
If you want to Pair your iPhone with your Car's Radio/Amp then you go through the pairing routine to match the two devices.
But you don't want the guy next to you connecting his music into your radio so he is required to "Pair" first
Was This Helpful?
Then tick the box!
Jun 29, 2014 | Cell Phones
Add code to 1 and then to onother devince
May 26, 2013 | Computers & Internet
Bluetooth pairing
its so simple just pair your bluetooth on your laptop to your mobile when its asks for code just press number 1 and it will asks again on your mobile and press gain number 1....its done..
Apr 27, 2013 | Nokia 6120 classic Cellular Phone
How can I put use it on my samsung phohe
Hi, Problem solved. All you need to do is to know how to pair the headset with your phone. Ones you pair the phone to your headset,your done..
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps...
Oct 29, 2010 | Mizco Radio Communications
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
Bluetooth Connecting Problem in Laptop
GO TO THE BLUETOOTH SETTINGS AND ALLOW ALL DEVICES MAKE SURE U PAIR THEM AND THAT BOTH PHONE AND PC ARE DISCOVERABLE USE THE SAME PAIRING CODE WHEN ASKED 4 1...EX.0000
Oct 25, 2009 | Samsung OmniaHD i8910 Smartphone
Hand book for bluetooth
According to the manual, do this:
  1. Park the car
  2. Press the Speech button
  3. Say "Setup"
  4. Say "Pairing Options"
  5. Say "Pair a phone" when prompted
  6. It will ask for a 4 digit pin -- tell it one (this is the pin you will use on the phone as well)
  7. Confirm the pin number if it asks
  8. start doing your pairing process on the phone, using the number you said in the step above
  9. Once it's paired from the phone, the car will ask to name the phone.
  10. Then the car will ask for connection priority, from 1 to 7, in case there is more than one paired phone in range -- it will connect to phone with the lowest number
  11. It may confirm your phone's name and priority, then it should tell you the pairing is complete.
May 05, 2009 | 2009 Mitsubishi Outlander
How do I attach my universal bluetooth haedset to my nokia n70
it should go like this
menu/connections/bluetooth/paired devices/options/add new device (pair new device)/the BT will go ON tt will find new devices select one that you want to pair wait for the connection then it might ask you for some kind of code unless the other device is mobile from other user and he put some other code for himself than you will need to ask if not just type 0000 or 12345 everything is automatic and it should be easy - i dont know if that 100% accurate cos i sold mine n70 and now i have e51 but it should go as i said
Jan 06, 2009 | Nokia N70 Cellular Phone
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
