Question about OEM Systems 1998 1999 2000 2001 Ford Explorer Remote Keyless Entry Key Fob with Simple Self Programming Instructions
Key fob works about 1/10 of the time
It works maybe one out of 10 times and I tried to program but I couldn't get it into programing mode
    Genius:
  • 1,198 Answers
Key fob batteries can wear out. Easy to change.
Posted on Nov 24, 2013
Program new key fob for Cadillac cts 2003
There are several methods of doing this - but your 2003 requires that you either go to the dealer for them to add a FOB with special equipment (ask if they'll do it for free - can't hurt). If you have time to kill, you can do it yourself with Method 3 as described and found at:
Key Fob Reprogramming General Cadillac Forums
Method 3 - Key Fob Auto Learn
This procedure will first erase all known key fobs. The procedure will then program a single or multiple key fobs. Method 3 is a series of three 10-minute key cycles, for a total of 30 minutes. This procedure requires that you have a replacement key fob and the vehicle mechanical key.
Important: All previously programmed key fobs will be erased upon completion of the 30-minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known good key fobs in the vicinity of the vehicle when programming with Method 3. If the RCDLR recognizes a known good key fob during Method 3 programming, the programming mode will resort to Method 1.
The vehicle must be OFF.
Place the replacement key fob in the console pocket with the buttons facing forward.
Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
The DIC will display a message: OFF/ACC TO LEARN.
Press the OFF/ACC portion of the ignition button.
The DIC will display a message: WAIT 10 MINUTES, then it will count down from 10 to 0, one minute at a time.
When the counter reaches 0, DIC will display OFF/ACC TO LEARN.
Repeat steps 5-7 two more times, for a total of 30 minutes.
A beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased. When fob 1 is programmed a beep will be heard and the DIC will display a message: READY FOR FOB 2.
Additional key fobs can be programmed by taking fob 1 out of the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode.
If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
Operate the active portion of each key fob in order to finalize the programming sequence and verify correct system operation.
Feb 25, 2015 | 2003 Cadillac CTS
What caused my '05 mazda 6 key fobs to stop working
Loss of programming maybe or a faulty keyless entry module.
Nov 01, 2012 | 2005 Mazda 6
Crimestopper SP501 car alarm/remote starter will not respond. The 2 way one doesn't work, the sidekick does.
You need to program your crimestopper sp-501 key fobs, you need to program both the 2-way and the 1-way key fobs, during the same key fob program session. First find your valet button/switch, when you have found it, turn your ignition on and press the valet button four times, if you have a toggle type switch for a valet switch, toggle it up and down four times, when its in remote key fob program mode, it will honk your horn 4-times followed by 4-parking light flashes. Once your have done this press the lock button on the 2-way key fob, horn will honk and the 2-way will sing a little song to confirm programed, then press the lock button on the 1-way key fob the horn honk will be your confirm programed. turn ignition off this will exit you from program mode. then shut all doors and test key fobs for operation functions....hope this helps you out
Dec 03, 2011 | 2006 Hyundai Sonata
Replaced chip on key on 91 DTS and car lost all power while driving. It shut down and nothing works.
There are 4 methods for programming key fobs. Up to 4 key fobs may be programmed to the remote control door lock receiver (RCDLR). Each programmed key fob is given a position of #1-#4 in the RCDLR memory.
Method 1 - Key Fob Quick Learn This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
Place a known key fob within the interior of the vehicle.
The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4).
Place the replacement key fob in the console fob pocket with the buttons facing forward.
A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED.
If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode.
Method 2 - Key Fob Slot Programming
This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicle mechanical key, and a scan tool.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
Install a scan tool.
Use the scan tool, to access the following:
• Vehicle Control Systems
• Computer/Integrating Systems
• Module Replacement/Setup
• RCDLR
• Program Key Fobs
Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to.
Place the replacement key fob in the console pocket with the buttons facing forward. A beep will occur indicating programming completion. The previously known fob is now erased.
If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming.
Remove the scan tool.
Method 4 - Service Programming System Fob Programming
This procedure is a 10-minute relearn procedure using the Techline Terminal with SPS software. Once the 10-minute timer has expired, the fobs can be programmed similar to Method 2 using slot programming. A scan tool, Techline Terminal, and a replacement key fob are required to perform this procedure.
Place the vehicle in the Vehicle On, Engine Off mode.
Connect a scan tool to the vehicle.
Insure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
Turn the vehicle OFF.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10 minute relearn procedure.
When the 10 minute relearn procedure has completed, use the scan tool to access the following:
• RCDLR
• Program Key Fobs
If programming additional key fobs, repeat steps 12-13, or press the OFF/ACC portion of the ignition switch to exit programming.
Oct 26, 2011 | 2006 Cadillac DTS
Keyless entry remote programming
Hello here is the instructions for programming the key fobs
This procedure will add, replace, or invalidate all key fobs. This procedure requires that you have a known good key fob available, a new/replacement key fob, the vehicles mechanical key, and a scan tool.
Method 1 is also used for the initial programming of fobs to a new replacement RCDLR. In this instance, the new RCDLR comes ready to learn the first key fobs introduced. Perform the learn procedure as outlined, with the exception that the new RCDLR does not require a known good key fob be placed within the interior of the vehicle.
Note: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Methods 2 or 3 must be used in this instance.
  1. The vehicle must be OFF.
  2. Place a known key fob and any new/replacement key fob(s) to be programmed in the cupholder inside the vehicle. DO NOT place any fobs in the console fob pocket at this time.
  3. Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
  4. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4). → If the DIC displays: OFF/ACC TO LEARN, the known fob has not been recognized. At this time, programming will revert to Method 2.
  5. If the DIC is displaying the correct fob number that needs to be programmed, skip ahead to step 9.
  6. If the DIC is not displaying the correct fob number that needs to be changed (i.e., the DIC is displaying: READY FOR FOB 3, and you wish to program FOB 1), use the scan tool to access the following: • Vehicle Control Systems • Computer/Integrating Systems • Module Setup • Remote Control Door Lock Receiver • Program Key Fobs
  7. Select the fob position you wish to program: Note: Selecting Invalidate All Fobs will erase any known fobs and will cause the DIC to prompt READY FOR FOB 1, requiring all fobs to be relearned to the vehicle.
    • Invalidate All Fobs • Program Fob 1 • Program Fob 2 • Program Fob 3 • Program Fob 4
  8. With the fob position selected, press the PROGRAM soft key on the scan tool. The DIC should display: READY FOR FOB X (X = fob 1, 2, 3 or 4, depending on the selected position)
  9. With the DIC displaying the correct fob position that is to be programmed, place the new/replacement key fob in the console fob pocket with the buttons facing forward.
  10. A beep will occur once the fob has been learned.
  11. If programming additional key fobs and there is no DIC prompt that indicates READY FOR FOB X, repeat steps 7 and 8.
  12. Exit programming mode by pushing the OFF/ACC portion of the ignition switch. Note: Failure to exit programming mode (press OFF/ACC) prior to pressing the UNLOCK button of each key fob programmed will result in that fob being inoperative. Pressing the UNLOCK button completes the programming sequence and is require to ensure transmitter operation.
  13. Press the UNLOCK button on each key fob that was programmed to finalize the programming and confirm system operation.
Nov 03, 2010 | 2006 Cadillac STS
2002 silverado single cab,haveing trouble getting into programe mode for key fob programe.
this is a fairly simple fix, you will use a method called 3-10's:
step 1 is to turn key on engine off.
step 2 is turn key to start briefly then let off (maybe a second and then just let off key)
step 3 remain inside vehicle do not touch anything for approx. 10 mins. then on your message board the security will quit blinking .
step 4 at this time you will turn the key off for FIVE mins. and turn back on.
repeat step 1-4 TWO more times, after this time you can turn the key off once again and your done the next time you cycle the key, the fob should be programmed to your computer. good luck
Mar 07, 2010 | 2002 Chevrolet Silverado 1500
Programming a keyless entry remote
Key Fob Auto Learn
Do not place any known good key fobs in the vicinity of the vehicle when programming.
Good luck and hope this help's keep me posted, there are 3 other methods and the 5th method is a tech 2 scan tool that the dealer uses but this should work on your year of cadillac.
Jul 01, 2009 | 2003 Cadillac Deville
Programming instructions for a 1999 Chrysler 300M remote fob
Manual Programming Procedure (non scan tool)
1. Connect pin 1 of the 16-way data link connector to chassis ground or to pin 4 of the 16-way data link connector.
2. Close all doors, turn ignition key to off.
3. Turn ignition key to Accessory.
4. Turn ignition to off, door locks will cycle once (in programming mode).
5. For each key FOB, press any button 3 times in a row to program code. When programming is complete, the door locks will cycle once.
NOTE:
IF A SECOND KEY FOB REQUIRES PROGRAMMING, IT MUST BE PROGRAMMED WITHIN 1 MINUTE OF PROGRAMMING
THE FIRST FOB PROGRAMMING. PRESS ANY BUTTON ON THE SECOND FOB 3 TIMES TO PROGRAM ITS CODE. WHEN PROGRAMMING IS COMPLETE, THE DOOR LOCKS WILL CYCLE ONCE.
6. The programming mode finishes after the following:
a. Programming of two key FOBS is completed.
b. One minute has passed since programming.
c. Pin 1 of 16-way data link connector is removed from ground connection.
d. Ignition switch is turned on.
e. Any of the doors are opened.
Apr 09, 2009 | 1999 Chrysler 300M
Key fob programin
I would suggest going to the Bentley Publishing site here:
http://tech.bentleypublishers.com/forum.jspa?forumName=volkswagen.a.a3
and maybe take a look at Dan Reed's Mk3 site here:
http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/index.htm
Feb 19, 2009 | 1997 Volkswagen Jetta
OEM Systems 1998 1999 2000 2001 Ford Explorer Remote Keyless Entry Key Fob with Simple Self Programming Instructions Logo
141 people viewed this question
Top OEM Systems Home Security Experts
Lawrence Oravetz
Christian Krentz
Christian Krentz
Brett Duxbury
Brett Duxbury
Are you an OEM Systems Home Security Expert? Answer questions, earn points and help others
