Question about Craftsman Garden
Water spraying out plastic nut on side of pump
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check for a cracked nut or broken o-ring
Posted on Nov 27, 2013
Rear windscreen wash not working on Skoda Octavia
Remove cover from rear wiper arm (it is covering the wiper arm nut) gently ease off the plastic moulding in the middle of the nut try squirters if water is coming out unblock the water jet holes in the plastic moulding
Jun 29, 2012 | Skoda Octavia Cars & Trucks
All of a sudden it app eras that water isn't being distributed in a wash. I have put water in from a bowl, and it pumps it around, and discharges on cycle. No blockage, because it wouldn't...
Your spray arm jets are probably clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 22, 2011 | Electrolux 23 in. ESL6114 Built-in...
The pump is running, but the water is not flowing as you might expect. I believe the pump may have debri somewhere, and I would like to clean it out, but can not remove the lower arm. It has a flat...
Number 6 in the picture HERE is the chopper which is probably plugged with food and/or debris. The wing nut you desrcibe turns CLOCKWISE to release the spray arm.
Jan 13, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
How to remove lower spray assembly in order to clean water filter
There should be a plastic nut holding the spray arm. Remove the plastic nut and the spray arm should release.
Does this help you?
Vic
Jul 23, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Remove water pump have removed outer plastic blades of viscous fan and the four small bolts behind the water pump it seems loose but will not come away, is it just the internal impeller blades dont want to...
what's up led, the large viscous nut is loosened in the clockwise direction. after you remove the 4 nuts on the water pump, you should see one hole on each side of the water pump body. if you take 2 bolts out of the thermostat housing, you can use those to thread in the pump body holes.slowly tighten each bolt equally and the pump should come out. to install a new pump, lubricate the o-ring on the new pump and just push in by hand.
Mar 21, 2009 | 1996 BMW 318
No spray
pump part number is 2107181, the diverter valve # 2136988. You can Bissell and they can tell you who may have parts near you, or you maybe able to order thru Bissell.com. Before you took it apart, were you getting water to spray out of the hose. If you were the the heater is plugged and won't allow water to spray out the bottom.
Feb 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
GE PROFILE SIDE BY SIDE water line tube
Sounds like you are talking about the plastic nut that screw onto the water valve. That nut should just pull off. May have to pull kind of hard then just push onto the new line. Is this what you are talking about? Let me know.
Oct 10, 2007 | Maytag MZD2766GES Side by Side...
Garden Logo
111 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
