Question about Samsung RF26XAEBP
Left door flap clips - Samsung RF26XAEBP
    Champion:
    Habit-Forming:
  • 275 Answers
Contact Samsung for all spare parts they will direct you to the nearest supplier.
Posted on Nov 29, 2013
Good day! The center flap (vertical hinged flap) no longer rotates back in when closing the left door. Result: the flap remains "out" when closing the door thus banging up against the right door.
Their is a factory issue on some models call the factory to see if your unit is a defective unit. Other wise the door flap has to be replaced. Not cheap..
Oct 30, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
How do I open the front of a Meile W911 Front loader
remove soap draw, remove screws on left hand side(T20), open drum door, three 10mm bolts around drum, open filter flap and unhook black hose from flap if there is one, the bottom left hand corner sits on top of a metal clip to hold it in position just pull to remove,
Sep 18, 2014 | Washing Machines
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
Right door flap not hugging door when ioening left door with right door already open
The doors have to be adjusted. They may have moved out of their intended alignment over time
May 01, 2013 | Frigidaire FGHG2344MF Bottom Freezer...
Interior blower only blows up to warm on 1997 A4 2.7ltr
Check the blend door cable for proper attachment to the control panel and to the blend door. Try opening the door manually to see the you can get hot air out. If not, the door may be broken inside the heater box. If yes, correct/adjust the cable attachment for proper operation.
REMOVAL & INSTALLATION
1990-97 Passat Models
Install the cable ends marked with a white or blue band to the control head assembly. The cables must be attached to the control head before connection to the system air flaps.
  1. Remove the climate control head from the center dash assembly to access the control head cable ends.
  2. Remove the lower dash panels as necessary to access the cable lever arms.
  3. Attach the airflow distribution cable (cable 2) to the airflow distribution knob's lower control lever.
This cable can be identified as follows:
Operates the mode/central air flap Cable has a black sleeve and is 25.0 inches (634 mm) long Cable is marked with a white band
  1. Press the cable's sleeve against the control head stop and install the retaining clip.
  2. Attach the temperature control/air blend cable (cable 3) to the air temperature knob's control lever.
Operates the temperature control/air blend cable air flap Cable has a blue sleeve and is 21.0 inches (535 mm) long Cable is marked with a white band
  2. Attach the airflow distribution cable (cable 1) to the airflow distribution knob's upper control lever.
Operates the footwell/defroster air flap Cable has a black sleeve and is 37.5 inches (954 mm) long Cable is marked with a blue band
  1. Install the cable such that the blue band is over the retaining clip mount and install the retaining clip directly over the blue band.
  2. Install the climate control head.
  3. Set the air flow distribution knob to defrost.
  4. Connect the longest airflow cable (cable 1) to the footwell/defroster flap lever on the heater's air box.
  5. Press and hold the flap's lever toward the retaining clamp perch and install the cable retaining clip.
  6. Set the airflow distribution knob to the Vent position.
  7. Connect the short airflow cable (cable 2) to the central/mode flap's lever.
  8. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of both air flaps making sure they can be heard contacting their stops.
  9. Set the temperature control knob to full cold.
  10. Connect the blue-sleeved cable (cable 3) to the air blend/temperature flap's lever.
  11. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of the air blend/temperature flap making sure it can be heard contacting the stops.
Fig. Side view of the control head and cable location. 1. Footwell/defrost flap cable-2. Air distribution cable-3. Temperature control flap cable
Fig. Temperature flap cable location and adjustment
Nov 24, 2011 | 1998 Audi A4
Re: the "flap panel" seal between the two doors;the top clip on the flap panel became unclipped. How can I re-clip it?
I have bad news for you. The schematic i see shows you have the french door style refrigerator, with a "finger" that is utilized to close the door securely closed. This finger is located at the top of both fresh food doors, and often breaks off. If this clip is the finger im referring to, then the bad news i have is that the only way you can repair this, is to replace the skin of the door, or the door itself. When i first came across this issue at a customer's house, I was told then that the cost would be several hundred dollars.
sorry to be the bearer of bad news, please dont shoot the messenger.
Visit my website for service or to ask general refrigerator questions: www.FixMyFridge.net
Mar 17, 2010 | KitchenAid KFCS22EVMS Stainless Steel ...
Maytag ensignia dryer MDE7657BYQ. Are the flaps
yes it can be tightened, you would have to take off the door, there should be 2 screws on left and 2 on right, then you would have to take off the dark brown like bolt on the left and right, there is a long L shape clip that holds top to front. Once you lift top tightened the bolt or add a bolt to the baffles..
Sep 11, 2009 | Dryers
2004 Honda Odyssey EX brake light replacement. How do you remove
open the rear hatch. Next to the brake light assembly, between it and the hatch there are two flap doors in the brake light trim. Take a small flat blade screwdriver and open these doors. The hinge side of the flap is nearest the hatch opening. When opened, the flaps will reveal two screws. Remove these. Then wrap a flat blade screwdriver with some tape (protects the paint) and put the blade at the front outside corner of the brake light assembly. Pry gently rearward and a plastic spear point clip will release. With the assembly off, you can see how to twist out the bulb sockets and replace the bulbs. to replace, put the spear point clip in first, replace the screws, and close the flaps in the trim.
May 30, 2009 | 2004 Honda Odyssey
2002 Honda Odyssey brake light replacement
open the rear hatch. Next to the brake light assembly, between it and the hatch there are two flap doors in the brake light trim. Take a small flat blade screwdriver and open these doors. The hinge side of the flap is nearest the hatch opening. when opened, the flaps will reveal two screws. Remove these. then wrap a flat blade screwdriver with some tape (protects the paint) and put the blade at the front outside corner of the brake light assembly. Pry gently rearward and a plastic spear point clip will release. With the assembly off, you can see how to twist out the bulb sockets and replace the bulbs. to replace, put the spear point clip in first, replace the screws, and close the flaps in the trim.
Mar 05, 2009 | 1997 Honda Odyssey
Samsung RF26XAEBP Logo
62 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
