Question about Denon AVR-3200 Receiver
Denon AVR-3200 wont go into standby mode
When i press the power button, the receiver wont go into standby mode. It seems as tho the power button on the remote doesnt do anything. I also have an AVR-1804 and have tried its remote on the 3200 with no result. All other functions (i.e. volume, source changing etc etc) work just fine. Any thoughts as to what im doing wrong here?
    Top Expert:
  • Denon Master
  • 39,223 Answers
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Posted on Nov 24, 2013
Testimonial: "Right, and thats my point. The power button on the remote does nothing. The power button on the receiver itself is the type that has 2 physical positions (i.e. it stays in when on, and physically is further out of the unit when off). So, for it to operate the button has to be in the further in position, my problem is that makes it to where you have to walk over to the unit to turn it off making the power button on the remote useless unless the unit has a standby mode. Hence my question."
  • 2 more comments
  • Dug Thompson
    Dug Thompson Nov 24, 2013
    Well, it has a physical button on the receiver itself that isnt the type that toggles a relay inside the unit. Im not sure what the proper name for this type of button is, but it stays in when you press it and pops back out when you press it again. Anyways, the AVR-1804 i also have is merely a toggle button and either engages standby or disengages it. The 3200 has this other type of button that kills it entirely making the remote useless until you press the button on the unit again. Im trying to figure out how to be able to turn the receiver on and off with the remote as opposed to having to press the button on the unit. Laxy, i know. but theres gotta be a way to turn it off with the remote.
  • Dug Thompson
    oops, lazy. not laxy lol
  • Dug Thompson
    Dug Thompson Dec 20, 2013
    Any ideas on this? I just cant believe that the unit cant be powered on/off with the remote
  • Bruce Teter
    Bruce Teter Jan 20, 2014
    same problem - remote will not turm the power on (it wil do everything else including turning th power off
2 Suggested Answers
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
I have a Denon avr 2801. My standby light is flashing and i cant seem to reset it. I have tried pressing the a and b buttons together and then turning the power on, all the lights flash but thats it.
Hello
There is always a constant 5v for the device to go to standby.and power on when you press the power button .
This flashing is not to reset the device it shows that there is a problem with power supply.
the regulators are burned or over voltage ...
it needs service .
hope this helps
good luck
Jan 20, 2016 | Denon Audio Players & Recorders
How can i run speaker test tone without a remote for a Denon avr 3200
The setup mode can only be entered using the remote on this model of Denon receiver
Mar 10, 2012 | Denon AVR-3200 Receiver
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
My AVR 391 goes on Standby and freezes there.
Seems you cannot fix this issue yourself. If the unit is still under warranty, Denon will replace a chip which has a flawed firmware. The unit cannot be updated remotely and a physical repair is necessary.
Sep 18, 2010 | Denon AVR-3200 Receiver
My denon AVR 1803 WON'T TURN ON
First make sure you you have the power plug plugged into the unit and a hot 110 outlet, press the on/standby button on the front of the unit and if no power return to store
Feb 23, 2009 | Denon AVR-1803 Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
Can't get off Standby mode
plug out the set and start over if it does not work call a tech to look at your set to verify.good luck.
Apr 07, 2007 | Denon AVR-3200 Receiver
300 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
