Question about Belkin Components Belkin Universal Wireless A/V Adapter
Dns error I connect my already setup Belkin AV Adapter to my Xbox 360 and upon testing the connect via "Test Xbox Live Connection", I get a DNS error. I've tried powering down my modem, router and Xbox (in the proper order) and trying again, but with no avail.
IP ADRESS FAILED ON XBOX 360. TRIED 2 DIFFERENT ROUTERS SAME ERROR
xbox configures the connection automatically as long as it is able to detect an internet connection(either wired or wireless). For wirless connections though, make sure xbox is using the correct security key or wep key for the wireless connection.
Mar 22, 2009 | Linksys Wireless-G WRT54G Router
IPaddress failed
When this sort of thing happens it is usually a DNS error. The easiest thing to do would be to cycle your network. You can do this by unplugging your dsl/cable modem for a minute and plugging it in again.
XB360 also has a network test option that will tell you where in the network the connection is failing in the case that it is not a DNS problem.
Jan 16, 2009 | Microsoft Wireless Network Adapter Xbox...
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
Connecting to xbox live
Try this Dns Address
4.2.2.1
4.2.2.2
Oct 02, 2008 | Microsoft Xbox 360 Console
My xbox 360 says its connected to the internet, but it wont sign in on xbox live
To troubleshoot your Xbox Live connection from the Xbox Dashboard:
  1. Go to the System area of the Xbox Dashboard.
  2. Select Network Settings.
  3. Select Test Xbox Live Connection.
  4. After the system has completed its tests, select More Info to learn more about your network, paying close attention to any test that failed.
    In each case, the More Info section will offer tips for correcting the conditions preventing you from accessing Xbox Live.
  5. Select Edit Settings to adjust your:
    • IP Settings (including IP address, subnet mask, and gateway)
    • DNS Settings (including primary and secondary DNS servers)
    • PPPoE Settings (including user name, password, and service name)
    • Advanced Settings (including host name and altern
Oct 01, 2008 | Video Game Consoles & Games
MTU setting
Browse to the router's setup page, should be 192.168.1.1 or 192.168.1.0 and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Setup
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address = 192.168.0.1
Subnet Mask = 255.255.255.0
Gateway = 192.168.0.1
Static DNS 1 = 192.168.0.1
Static DNS 2 = 192.168.0.1
Static DNS 3 = 192.168.0.1
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Xbox live
You should have no problem w/ comcast.
First make sure your computer can connect to the web with the same connection. If it does then you should be good to go. My guess is that you are not able to from your set up the way it is configured. Make sure your signal is split with a router. Your IP and DSN should set automatically from within the Xbox. Don't try to manually set up the IP address or the DNS.
Make sure you run your test setup though the Xbox and pay attention to what it says. Read the solutions that are offered for every fail test. Be patient. I am confident you can do this. But to repeat. Make sure you can log onto the web with a computer from the very same TCIP plug that you will use on the 360.
Sep 11, 2008 | Microsoft Xbox 360 Console
CAN"T SIGN IN TO XBOX LIVE
You might not have been banned. Not being able to connect to the DNS or having it fail can be caused by a few things:
The DNS address serves couldn't be reached
The info on the DNS server couldn't be snagged from your ISP or the DHCP server
The DNS values in the dashboard are wrong.
I don't want to come off like I am insulting your intelligence, but check your internet connection to make sure you have the ability to connect. I'm sure it is all in proper order. So the next thing you need to do is check to see if you IP is set and passes all the tests. If it isn't then you can click the more link on the test page to follow the directions on how to fix it.
You may also want to check out if you are using a XBOX live compatible ISP. Click on Learn More to see if you are using the right ISP or to adjust your settings. You can also check out the connectivity wizard to find out if there are some other issues revolving around this.
Still running into problems!?!?!? try running the modem directly into your XBOX. This has helped me in a few time of need.
Here are some helpful links on what you can do when your DNS fails:
http://xbox360help.blogspot.com/2007/03/dns-failed-on-xbox-360-live-test.html
And a link to a forum discussion regarding failed DNS
http://forum.teamxbox.com/archive/index.php/t-411837.html
Mar 04, 2008 | Microsoft Xbox 360 Console
Belkin Components Belkin Universal Wireless A/V Adapter Logo
75 people viewed this question
Top Belkin Components Computers & Internet Experts
William Miller
William Miller
David Payne
David Payne
Are you a Belkin Components Computer and Internet Expert? Answer questions, earn points and help others
