Question about Whirlpool WGD9400ST Front Load Gas Dryer
Wgd9400sw solenoid sticking
Rattling noise when it is cycling the heat on
  • Linda
    Linda Nov 25, 2013
    I'm sorry to have bothered you. I checked my records and found that this dryer was still covered by an extended warranty. I have called for service. Thank you for your time. If you like you can remove my listing.
    Sergeant:
  • 479 Answers
I would replace the solenoid
Posted on Nov 25, 2013
Solenoid rattle on start up. Goes away immediately on start. V 6 motor
peugeot 407 v6 3.0 very short-time rattling(grinding) noise at ...
? 0:13
https://www.youtube.com/watch?v=ZRJzci7qvNA
Feb 27, 2012 - Uploaded by reza679
peugeot 407 v6 3.0 very short-time rattling(grinding) noise at cold-start, source ... but a friend told me it can be anything else as well (like those solenoids)! ... C6 makes when starting cold - is that a VVT or a valve lifter noise?.
407 [Archive] - Peugeot Forums
www.peugeotforums.com > Peugeot Forums > Peugeot Models
Mar 22, 2011 - Key replacement · Wishbones for 407 · ESP/ASR Faulty · RT4 VIN coding · 407 1.6 2004, Crankshaft pulley.. size, part number.. 407 driver door lock replacement ... Peugeotforums.com Suggestions and Help [Archive ...
Mar 24, 2011
General Discussion [Archive] - Page 4
Mar 21, 2011
More results from www.peugeotforums.com
Jan 26, 2016 | 2006 Peugeot 407 1.6
How do I stop the buzzing noise when in heating cycle?
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
Apr 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Idles real high at stops and makes noises in the exhaust under car.
Check the throttle body make sure its not sticking. If its not sticking then the problem would be the EGR valve and sensor since they control the idle speed for the motor. Rattle sound under car might be a heat shield for the exhaust that came loose.
Feb 09, 2010 | 2004 Ford Escape
Theres a loud rattleing noise coming from the passenger front part of the car
mine just started making a rattling noise. i found it. it is some fuel solenoid that is clicking/rattling on and off
Dec 22, 2009 | 2006 Suzuki Forenza
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
LGd45el dehumidifier motor cycles on and off
dehumidifier motor making rattle noise
Apr 02, 2009 | LG Dehumidifiers
Rattling Coming from Engine At low RPM (stopped) and when accl.
If this sounds like a tin can rattle it is likely a loose heat shield on top of the catalytic converter. They come loose after time and corrosion take their toll.
Feb 25, 2009 | 2001 Lexus Gs 300
Whirlpool WGD9400ST Front Load Gas Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
