Question about Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher
Whirlpool Dishwasher Control Panel problems
Model DU9255GG2 Conttol Panel Problems
3 Suggested Answers
  • 11 Answers
SOURCE: Control Panel Problem on a Maytag DW MDBTT79AWW
I had this same problem, ordered the replacement control panel from whirlpool. The new panel worked for two weeks, then stopped working again. OUCH!
The replacement part costs $264.34 and has no warranty if you do it yourself.
I think I am now going shopping for something other than a Whirlpool or Maytag machine. They have terrible customer service.
Posted on Feb 09, 2011
  • 5 Answers
SOURCE: Hi, I have a maytag
Before buying new panel :-( it's worth to try to clean and reconnect J1 ribbon cable that connecting panel with control module - but in general panel and J1 ribbon cable are poorly designed and cable get fried in which case you have to replace whole panel.
Posted on Apr 24, 2012
Whirlpool Dishwasher will not start
Contact appliance repairman,
sounds like either a control problem, or the is a problem with the solenoid that opens up to let water in the dishwasher at initial start.
Jul 09, 2013 | Dishwashers
Regency problems
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Hi, I have a maytag quiest series 300 dishwasher and I seem to have problems with the control panel. The control panel does not light up and therfore i cannot switch the dishwasher on.
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Aug 02, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Whirlpool Gold Silent Partner IV Dishwasher - model Anyway, my PROBLEM is that the control panel isn't working!!! At all!!! Only the cancel button works... Do you have any solutions?
I think the problem here is there is water in the control panel. this can happen and short the other buttons out the cancel has its own circuit. I would recommend changing the control panel.
Apr 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Feb 12, 2010 | Maytag Dishwashers
Power to dishwasher but no power to panel
Open your console and check the continuity of the thermal fuse (clipped to the electronic control unit [ECU]).
Post your model number if you're still having problems and I'll try to assist you further.
Apr 04, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher Logo
61 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
