Question about Wilson Antenna Wilson 880-900802B W-1000 Roof Top Black 880-900802B
Grease under the Coil of a Wilson 1000 CB antenna
Three Question. I have three Wilson 1000 I have picked up and all three of them have grease under the coil Will that short out the CB radio? burn up linears? and burn out a new CB the first time you key it up?
    Problem Solver:
  • 14 Answers
Animal greases and Metal grease will conduct electricity. I use silicone grease for my receiving antennas.
Posted on Nov 24, 2013
Whats the best antenna and location on an f250 ford p/u ext cab superduty
Something like either a Wilson 1000 or 5000 magnetic mount on the roof--coil and whip unit detach as needed.
Apr 12, 2012 | Cobra 29 LTD CB Radio
How to Eliminate Static in the uniaden pc68xl Iam running a wilson lil wil anntena
ditch the wil and invest in a better antenna wilson 500 or 1000 thoes wil's dont seal in the rain and your swrs go way up! when wet.
Dec 12, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Having trouble setting swr .moved anttena up and down 1/4 inch at a time and there is no change
There are several things that can cause you not to be able to get an acceptable SWR.
The first is the most obvious. Poor antenna, or bad coax. Make sure your coax is good. Make sure the antenna is mounted in a good location.
Some things I have seen that cause this problem.
  • Wilson Little wil, almost impossible to get under a 1.6 SWR.
  • Fiberglass antenna's, a break in the wire near the top of the antenna. Will show the antenna as being too short, and adjusting the top will do nothing. This antenna is no good.
  • Common mode current. This is when the RF is traveling back down the outside of the coax, and or causes the coax to act like part of the antenna. SOLUTION. As close to the antenna as you can, take 6 to 8 inches of coax, and coil it into a tight coil, about the diameter of a spray paint can. In fact using a spray can to wrap the coax around works well. Use electrical tape to secure the coil so that it will stay tight and uniform. This will stop common mode.
  • missing foil/vinyl membrane on bottom of magmount antenna. This is essential for the antenna to see ground plane.
  • bad connections on coax connector.
  • Cracked isolator on stud mount.
  • incorrect procedure for taking SWR reading.
  • Poor location of antenna. E.g. antenna's load not above roof of vehicle.
  • Incorrect length whip being used.
  • corrosion of any part of the antenna system.
There are some cheap antenna's out there that you just can't get lower then say a 1.5 or worse, like the wilson little wil. Wilson makes great antenna's. The 500, 1000 and 5000, as well as their silver load antenna's are excellent. I have been able to get them all to at least a 1.1 SWR, and some like the 5000, and silver load fiberglass whip to 1.0 using an analyzer. The Little will is just a poor antenna. Anything under 2.0 SWR is okay of a barefoot radio, although I don't like going over 1.5 my self. A barefoot radio, will do a 2 swr all day. If the radio is stock, and not peaked and tuned, 2 swr is fine and won't hurt the radio.
You should always try to get the lowest SWR that you can in any case. The lower the SWR, the more RF energy is leaving the antenna. As well, receive will improve the closer you get to a perfect match. This is known as being "On Que".
Check everything I have listed that applies. And if nothing fixes it, you may want to try a different antenna. Some antenna's just don't work well on certain vehicles.
Oct 13, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have uniden cb and I can't get the pa to work it just play the weather and my antenna is broken if it has anything to do with it
Hi, my name is John. Some twenty-three channel radios have the PA located between channel twenty-two (22) and channel twenty three (23). Make sure you have the right PA plug for it, as far as the antenna, get you a good one, say a Wilson 1000 or a Wilson 2000, they are great antennas, magnet mount. You need to press the PA button. Hope this was helpful...Rate this solution on the four thumbs-up. .Good luck John.
Oct 03, 2010 | Radio Communications
Cb radio
As for me ,the Wilson 1000 or Wilson 2000 are the best mobile antenna for a mobile. I have out talked a lot of base antennas with them, just put it on the top of car in the center or trunk, or middle of cab of truck, with a good SWR and you are talking and receiving. great antenna. ...hope this helps..
Jun 01, 2010 | Cobra 29 LTD CB Radio
I have a coba ultra 19 iii in myt truck what is
You need to buy an antenna that is designed for use with a CB. A couple of good ones are the Wilson 1000, Wilson Lil' Wil, K30, K40. You will only pick up "everything" within the 40 channels with that radio.
Jul 09, 2009 | Cobra 19 Ultra II CB Radio
Maximize my cobra18 WT ST
A good antenna goes along way for your transmit distants. It does close to 90% of the work on that side of things, but also remember that the radio itself does most of the recieveing. I good antenna brand to stick with is Wilson they make several units but for you a Wilson Little Wil would do the trick. There not real tall about 3' and cost around $40.00. If you want more performance a Wilson 1000 Mag mount is one of the highest performance antenna's on the market but its tall around 5' and cost somewhere around 80.00-90.00 . You can tune the radio and get alittle more out of it but not much, get a good antenna and go from there you will like it. Dont forget that any antenna has to be tuned (swr set) to the vehicle this will insure max performance.
Jun 24, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Radio questions
The radio goes from 10 -160 meters. You should get good results with the wilson 5000,even the 1000!
Wilson is a pretty good all purpose antenna.You can probably get the cb freqs if not an experienced tech can open it up for you.
Jan 25, 2009 | Radio Communications
Uniden squeel
You have an antenna problem. Get a good antenna, such as a Wilson 1000 & use the SWR function in the radio to tune it. Wilson antenna come with tuning instructions.
May 31, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
Wilson Antenna Wilson 880-900802B W-1000 Roof Top Black 880-900802B Logo
187 people viewed this question
Top Wilson Antenna Radio Communications Experts
eradiostore
eradiostore
Are you a Wilson Antenna Radio Communication Expert? Answer questions, earn points and help others
