Question about Welding Tools
200P AC/DC /PLASMA WELDER WONT WORK
HI STICK WELDER WORKS NO PROBLEM.. THE AC,FOR WELDING ALLOY ,POWERS UP ,BUT ONLY JUST ,AND THERES NO POWER ,LIKE PUSH PEDAL ALL THE WAY DOWN ,AND IS LIKE QUARTER OF THE POWER WHEN IT WAS GOING OK.. PLASMA SELECTION,HIT THE SWITCH FOR CUT,AIR FLOWS,AND ARKS,BUT NO POWER OUTPUT/PULSE,,BUT INSIDE THE MACHINE MAKES THE RAPID TICKING SOUNDS WHEN HITTING THE SWITCH AS IT USED TO BE WHEN IT WAS WORKING GOOD.. DOES ANYONE KNOW WHAT PART TO REPLACE?? LIKE IS IT ONE OF THE RELAY SWITCHES NOT CONTACTING OR MAYBE BURNT OUT??OR A DIOD OR SIMLAR ,I HAD REPLACE A FEW SUSPECT DIODS ALREADY WITH NO FIX..
Try cleaning the ground inside the welder. and make sure you have a good power supply ie. power cord. check the transformer for continuity and clean all the contacts ( are you sure the power inverter diodes are only passing current one way and are not "open" )
Posted on Nov 24, 2013
kevin_max
  • 37 Answers
SOURCE: hypertherm plasma cutter making weird air sound from inside unit
Open the cover (only after a day of not being plugged in).
Check the airline that comes in through the back of the case.
The air line has either fallen off or has a hole in it.
If you are a technician and don't mind working with thousands of volts of electricity that is inside the case, then and only then can you plug it in. Safety First. Rember the voltages inside this unit are lethal. It will not give you a second chance.
If you feel you are qualified, then plug it in and start it up, use it as normal, while at first watching from a 2 meter distance, you may immediately see and/or hear where the noise is comming from.
DO NOT under any circumstances put your hand or hands inside the box while it is live.
Try running a WOODEN stick (at least a foot long) along the length of the airline inside the case and around the valve as it enters the case. The sound should change in pitch when you find it.
If you think you have found it, DO NOT touch anything inside, until you have both DSCONNECTED THE UNIT from the power source and WAIT ONE DAY before putting hands inside the unit. Any storred or residual energy will have discharged by this time, making it safe to work on. Safety first. The voltages inside are lethal. This aplies to all Plasma Cutters. Good luck.
Posted on May 15, 2009
  • 225 Answers
SOURCE: cutmaster 50 does not shoot air when presss the trigger
check the air soleinoid.
Posted on Jul 05, 2009
  • 29 Answers
SOURCE: on my dc inverter welder 3 in 1 unit the plasma
Bad inverter.
Posted on Sep 28, 2009
GiantTechGuy
  • 25 Answers
SOURCE: Looking for manual for my mitech super 160 welder
When you press the torch trigger what sound/sounds do you hear from within the machine?
Posted on Oct 18, 2009
  • 60 Answers
SOURCE: My Airforce 400 Plasma cutter after few seconds of
Those plasma cutters work much better on 230 v I would switch over to get more power and better quality
Posted on Nov 20, 2010
If I turn the ac dc switch while what dose it do to the wielder. Now im not getting any juice to wield .thank you
Changes between AC and DC voltage at the electrodes.
Q: What Type Of Stick Welder Works Best For All-Around Use?
A: A welder with an AC/DC output, whether its an electric arc machine like Miller\'s Thunderbolt or a gas engine drive like Miller\'s Bobcat.
DC welding offers advantages over AC for most Stick applications, including: easier starts; fewer arc outages and sticking; less spatter/better looking welds; easier vertical up and overhead welding; easier to learn "how to weld" and a smoother arc. DC reverse polarity (electrode positive) provides about 10 percent more penetration at a given amperage than AC, while DC straight polarity (electrode negative) welds thinner metals better.
Q: Does An AC Output Have Any Advantages?
A: Yes, if you need to weld on material that\'s become magnetized from friction, such as when hay, feed or water constantly rub against a steel part. A DC output won\'t work because of "arc blow," where the magnetic field blows the molten filler metal out of the weld puddle. Because an AC output alternates between polarities, it enables you to weld magnetized parts.
Aug 19, 2014 | Computers & Internet
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Aluminium welding settings
Check your manual or the welding rods data sheet. The settings depend on what you will weld. Consult online manuals and welding charts. These will help you a lot.
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
Oct 07, 2013 | ARC Thermadyne Inverter Stick/TIG Welder...
I need to find parts for my welder lincoln the fan coolin is not working
Any welding supply house can either get you a fan, or direct you as to where to find one locally.
--W/D--
Feb 19, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I just bought a AC225 stick welder, there are two cables coming out of the machine, I don't know which one is the work cable and which one is the holder cable?
it doesn't matter which one you use because it's alternating current, normally the longer one is your electrode holder cable so you have more cable to move around with,but either way it will work, if it's a D.C. welder then all your doing is using reverse polarity and in some cases welding this type of welding is superior to straight polarity
Nov 14, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
Welding machine stops working after a few minutes of welding.
there is probley nothing wrong its called duty cycle.which means that if you are welding long periods or welding at max amps the welder will kickout to cool down.Look on your unit for the tag that tells imformation about your unit.It will show something like 30% duty cycle so that means you can weld 3 minutes at full power before the unit shuts down.
Mar 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding Tools Logo
234 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
