Question about Pool & Spa
How eazy is it to damage a pool pump - Pool & Spa
  • 372 Answers
Realistically, the damage can be done in a fairly short amount of time, within an hour. By far the most common damage pumps incur is due to "running hot". That's where the pump runs with no water flowing through it. The water in the pump pot can boil, which is above the melting point of some of the pump's parts and nearby fittings.
Posted on Nov 24, 2013
I have an air leak in intake line
Question:
What do I do if my pool/spa pump is loosing suction or prime?
Answer: by Osko Pool n Spa Pool Pump Losing Suction or Prime If your Swimming Pools Filter system looses Prime, it is caused by one of the following conditions.
Note: The lost of suction/prime is caused a leak which in turn sucks air into the system. The lost of suction/prime will be anywhere from the Main Pool Skimmer(s) to the Pool Pump. It will NOT be from the Pool Pump to the Pools Main Return(s).
1) First make sure that your water level is high enough so that the skimmer is not sucking air.
2) Check the Pump Pot Housing Lid Seal and be certain that its completely sealing and is not
Sucking air into the system. Check the lid for cracks. If either condition is true, replace the Pump Pot Lid Seal and/or entire lid
3) Check all fittings, clamps and hoses from the pools skimmer to the Pools Pump Pot Housing for wear, tightness and leaks.
4) Check Pool Pump Pot Housing for cracks.
If everything aforementioned in good working order, the next thing to check is the Pump Pot Housing Main Seal and the Pumps Impeller and finally the pump.
5) While the Pool Pump Motor is running, carefully inspect the area where the Pump Pot Housing attaches to the Pump Motor. See if there is any water leaking. Next, spray the area with water and see if the water is sucked into the Housing. If so, your Main Seal is damaged.
6) Disassemble the front half of the Pump Pot Housing from the back half and inspect the Pump Motor Impeller. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged.
7) Re-inspect the Pump Pot Housing Main Seal by standing the partially disassembled upright, with the Pump Motor towards the ground. Pour water over the impeller and into the cavity. See if the water leaks thru to the outside of the Pump Pot Housing. If so, your Main Seal is damaged.
8) Remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged.
If everything seems to be in good working order, then you need a new pump... not just replacement parts
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 18, 2013 | Hayward SAND FILTER, PRO SERIES
Whisperflo pump exploded
I am as of yet unaware of any means in which a pool heater will make a pump explode, but am intrigued, certainly. Actually, I have never heard of any pump "exploding".
I would assume that there must have been some restriction that caused some sort of failure. Can you be more specific about what kind of damage occurred?
Mar 15, 2013 | Pentair Whisperflo 2 Hp Pool Pump Wf8...
If the pump ran for some days without water (dry) what would get damaged inside the system?
Days is a long time. Impeller could be warped. Seal between pump and pump motor could be damaged.
I have seen damage to seals and impellet in less than 10 hours
Jul 24, 2011 | Waterway 1 HP HiFlo Above Ground Pool Pump
After turning the pump switch on. How do i get the pump to work
BEFORE YOU TURN THE PUMP ON YOU MUST PRIME THE PUMP ! IF YOU RAN THE PUMP DRY YOU MAY HAVE DAMAGED THE SHAFT IT MUST BE REPLACED ! II ITS A 20 FIX.. BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY ..
Jun 29, 2010 | Intex Automatic Salt Water System for ...
Pool won't drain
must replace motor the cooling fan is damage and the motor is over heating whrn the motor coll down it will start again
Apr 21, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
How do i replace the bearings on a whiperflo
not a easy task, the bearing are easy to damage . try looking for your local pool pump motor repair shop (your zip code) cost should be around 85.00 with a new shaft seal (a must !)
Mar 10, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Sun damaged pool noodles causing pump problems.
you just need to clean the filter. What kind of pool/pump do you have? If it has a cartridge filter it should be easy to take apart and spray off with a water hose.
Jan 19, 2009 | Pool & Spa
Pool & Spa Logo
21 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
