Question about Pool & Spa
What kindof damage would sucking saw dust up threw the swiming pool pump do
    Problem Solver:
  • 14 Answers
May need cleaning of the filter, impeller, etc. How much saw dust? If only a little likely no damage. If 50 pounds, the lines may be clogged, filter will need to be cleaned many times. Call your local pool clearer or supply store to better advise you. If the wood it toxic, you might also have problems. You will need the type of saw dust, regular, treated, CCA, etc and how much wood dust.
Posted on Nov 24, 2013
3 Suggested Answers
SOURCE: onga pool pump running but not drawing water from pool
Take out the pump pot basket and stick your finger in the hole towards the motor (make sure the motor won't kick on!!). What you should feel is the impeller. It has five grooves in the face of it and each one needs to be cleaned of foilage and debris. With every hole clogged in the impeller you lose 20% of your motors effeciency. With whisperflow brand the pump pot basket is poorly designed where debris like pine needles go straight through.
Griffin Pool Services
Las Vegas, NV
Posted on Jun 06, 2009
  • 366 Answers
SOURCE: pacer does not run on INTEX pool pump, no
make sure to check the diaphragm inside, check for deformity or debris stuck in it. You can take the unit apart just below the wagon wheel and push the white tube downward to expose the diaphragm.
Posted on Feb 03, 2010
My pool pump is not sucking enough water threw it and releasing it very slowly what do I do.
check for blocked inlets and filters check that the control tap is position properly as it may be recycling water and not direction the flow properly
check if the pump is running at full speed ( bearing problem)
failing that have a pump specialist check it out
Aug 03, 2015 | Pool & Spa
BCE Clifton 6x4 folding pool table and not a spa or swiming item
Sure but you might inform the people who are delivering or who you purchased the item from.
Nov 07, 2014 | Pool & Spa
I have an air leak in intake line
Question:
What do I do if my pool/spa pump is loosing suction or prime?
Answer: by Osko Pool n Spa Pool Pump Losing Suction or Prime If your Swimming Pools Filter system looses Prime, it is caused by one of the following conditions.
Note: The lost of suction/prime is caused a leak which in turn sucks air into the system. The lost of suction/prime will be anywhere from the Main Pool Skimmer(s) to the Pool Pump. It will NOT be from the Pool Pump to the Pools Main Return(s).
1) First make sure that your water level is high enough so that the skimmer is not sucking air.
2) Check the Pump Pot Housing Lid Seal and be certain that its completely sealing and is not
Sucking air into the system. Check the lid for cracks. If either condition is true, replace the Pump Pot Lid Seal and/or entire lid
3) Check all fittings, clamps and hoses from the pools skimmer to the Pools Pump Pot Housing for wear, tightness and leaks.
4) Check Pool Pump Pot Housing for cracks.
If everything aforementioned in good working order, the next thing to check is the Pump Pot Housing Main Seal and the Pumps Impeller and finally the pump.
5) While the Pool Pump Motor is running, carefully inspect the area where the Pump Pot Housing attaches to the Pump Motor. See if there is any water leaking. Next, spray the area with water and see if the water is sucked into the Housing. If so, your Main Seal is damaged.
6) Disassemble the front half of the Pump Pot Housing from the back half and inspect the Pump Motor Impeller. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged.
7) Re-inspect the Pump Pot Housing Main Seal by standing the partially disassembled upright, with the Pump Motor towards the ground. Pour water over the impeller and into the cavity. See if the water leaks thru to the outside of the Pump Pot Housing. If so, your Main Seal is damaged.
8) Remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged.
If everything seems to be in good working order, then you need a new pump... not just replacement parts
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 18, 2013 | Hayward SAND FILTER, PRO SERIES
Who often should I backwash sandfilter
I would let it run for about a minute depending on how clogged it was. Our backwash drain is very visible so we can see when the dirty water has left the filter, usually about a minute or two.
Apr 06, 2013 | Hayward SAND FILTER, PRO SERIES
Could you find the compound sentense lets go to swiming pool. its hot inside the house
"Let's go to [the] swimming pool, it's hot inside the house."
Mar 13, 2013 | Pool & Spa
My Bosch 4000 table saw will not stay running, it starts then it will just stop. it is not tripping the breaker, any sujections?
The motor control electronc control board ($40.00)is the most likely culprit. When you replace the electronic speed control board be sure and replace the brushes also as they will have very tiny pitting damage ($5.00)
What happens is that when the motor cooling port sucks in the saw dust contaminants the motor brushes and armature develop an intermittent contact which damages the operational characteristics of the control board - so blow motor out often with compressed air to remove contaminants. Don't ever operate this saw without a vacuum saw dust evacuation system (Shop vac,Etc.)!!
Aug 11, 2010 | Bosch 4100 09 10" Worksite Table Saw...
My blade won't cut threw the intier stock. like somthing is stoping it from breaching the deck. There is no saw dust hindering it anywhere and it used to cut right threw.
turn the bolt counter clock wise on the arm, this will allow the blade to go lower...don't go too far or u will cut into the base and or fence.
Aug 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
Can fire ants short out the run windings ?
YES . YOU MUST KEEP THIS AREA CLEAN AND WEED FREE . THAT MOTOR IS A AIR THREW MOTOR AND AND SUCKS IN ANY LOSE DEBRIS AND IT CAN GET INTO THE WINDINGS , START SWITCH.
YOU MAY WANT TO BRING THE MOTOR TO YOUR LOCAL POOL PUMP REPAIR GUY TO HAVE IT CLEANED ! ABOUT 75.00 WITH THE NEW SHAFT SEAL.. JAY
Jun 27, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
Need to trouble shoot a C4SL2N134 pump motor. need wiring diagram
WD40 IS A WATER DISPERSANT AND WILL CAUSE MORE DAMAGE THAN GOOD ,IT WASHES AWAY OIL AND GREASE.. YOU MUST HAVE THE START SWITCH SET ,IT SHOULD BE CLOSED FOR START AND OPEN WHEN RUNNING.. NEW BEARINGS ARE THE ONLY GOOD FIX . YOU CAN TAKE THE BEARING IN YOUR HAND AT A SLIGHT ANGLE AND SPIN THE ROTOR, YOU CAN FEEL ANY BEARING DAMAGE THREW YOUR HAND I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Jun 02, 2010 | Smith AO Pool Pump Motor
Notebook has fallen in to a swiming pool and still it is running, but not connecting to the wireless.
You are lucky it still is.
Dry it a bit more with a dryer and make sure the wireless switch is turned on(if you have one).
Apart from that water might have damaged the wireless card.
Oct 07, 2009 | Apple Computers & Internet
Pool & Spa Logo
26 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
