Question about ClickFree Computers & Internet
Wants to format ,will not open
I have files on this drive I do not want
Will i loose pictures & other files if i format my pc
Yes you will lose all files when you format.
If you want to save your files but cannot open Windows on your computer then remove the hard drive from your computer and connect this hard drive into an USB hard drive adapter. Plug this adapter and hard drive into the USB port of a working computer, this computer will see this as an external storage device, you can then open the folders on this drive and copy/backup the various folders and files.
After you have copied/backup your files, you can install the hard drive back into your computer to format and reinstall Windows.
Feb 06, 2012 | Lenovo Computers & Internet
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Sudenly kingstone usb changed to skymedi and doesnt formated
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
Win Vista & 7: double click the file cp006049.exe - select extract
For Win XP, first way
For Win XP, second way
For Win Vista & 7, first way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
My new Toshiba STORE ART 3 1 TB external Hard Disk is not working. i plugged it to my pc on windows 7. and it shows the drive in My Computer but when i opened it it saying that 'Please insert disk into...
Open your command prompt and format the drive type format volume [/fs:file-system]
volume: Specifies the mount point, volume name, or drive letter of the drive you want to format.
/fs:
file-system: Specifies the file system to use FAT, FAT32, or NTFS Floppy disks can use only the FAT file system.
Example.........FORMAT E: /FS:FAT32.....Press enter. E: is my second drive
May 19, 2011 | Computers & Internet
I want to format my pendrive but it is not formatting data how to overcome this problem?
If you have a Windows based computer click on the start menu, then my computer, select the drive from the removable devices section, right click on the drive, select format, then quick format and start. If that doesn't work then left click (double clicking) on the drive and open a folder, once opened drag the mouse over all files to highlight them. Once highlighted press control+Delete on your keyboad and that should remove the files and wipe the drive..
Apr 05, 2011 | Pen Drive IVO MP3 Player
My sandisk 8 gm is not open , when i try to open it as me that the disc drive is not formatted, do you want to formatte it now ?. what i will do. please help me becouse it inculded important office file...
The reason for which you are not able to open the pen drive is that Pen drive was formatted on a different computer with a different file system from a different OS and then the file was copied into it. And the computer on which you are trying to open the pen drive is having probably different OS which does not support that file system Pen drive was formatted with.
So all you have to do is to open the Pen drive on a computer that has OS same as on which file was copied into.
Thanks
Dec 08, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My pen drive is in RAW file system, I ca'nt open or format it.
Try to get a software called parted magic. its linux based and you should easily format the pen drive.
U can also try HP USB Disk Format Tool.
May 28, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Files in my kingston pendrive does not open up
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
Kingston Tech Support
May 03, 2009 | Kingston 4GB Secure Digital High Capacity...
ANY DRIVE DOESN'T OPEN????????
it's a virus, undetectable with antiviruses, there is a file named autorun.inf in the drive delete the file and recheck it.
Feb 07, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
18 people viewed this question
Top ClickFree Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Bill Boyd
Are you a ClickFree Computer and Internet Expert? Answer questions, earn points and help others
