Question about Philips 32PFL7332D 32 in. LCD HDTV
Blurry screen I have a Philips model 36PT832027 and the screen is blurry. Any ideas? Thanks!
I have a Philips HD model # 55PP935217 Projection TV.
The problem is that only the red and green show up on the screen. When you remove the front screen the blue is light up but you can barely see the pricture coming thru it. When you remove the top lens and set it off to the side, the blue light pack that it bolts to is not clear it has a deep burnt yellow look to it. Is it possible the part # P16LTG00BMB(U)is bad? The other two colors are clear.
Posted on Nov 23, 2008
Check the flyback
Posted on Jan 22, 2008
SOURCE:
Picture shows blurry
You will have to determine which of the picture tubes has contaminated fluid. To do this, you have to pull the screen off and see which tube is blurry. You will find a red, green and blue tubes when the set is on. To learn how to remove and replace the fluid, please check the following web site. www.TVRepairKits.com. Be sure you have the model number and know the symptoms you describe to repair this. Thanks for asking and show all hands of support!
Mar 29, 2011 | Philips Magnavox 9P6034C 60" Rear...
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
Blurry Philips TV model # 51PW936317F
The coolant will become congealed in Phillipd rear projections and the color will get very dim and hard to focus. You can get the coolant replace kit at the following link which contains the coolant for all 3 tubes and step by step instructions om CD. Heres a link to the kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 25, 2009 | Televison & Video
Blurry picture
You need to clean the projector lens on the optical engine using a soft cotton or, better yet, a chamois cloth. Also clean the mirror mounted inside the rear cabinet and also the front and rear of the screen itself.
If picture is still blurred then your the optical engine is most probably defective.
Dec 10, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture get blurry on right hand side
if the convergence is also off suspect convergence ic problem
Nov 27, 2007 | Philips 43PP9202 43" Rear Projection...
Blurry/Hazy picture on Philips Tv
as your problem is the picture has become blurry/hazy 1 it sounds me that there is a little sparking near high voltage section that is near flyback transformer.please get it check. 2 if it is ok then focusing anode wire going to crt base from flyback transformer is not making proper contact due to some foreign material deposited on it. please call tech person if you ae not aware of it as tv is a very high voltage device.
Oct 01, 2007 | Televison & Video
Philips 32PFL7332D 32 in. LCD HDTV Logo
306 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
