Question about ASUS B1M - Ultra-bright Wireless Led Projector
ASUS B1M PROJECTOR CANT CONNECT
CANT CONNECT WIFI
Asus x5dc cant find wireless key where is it ?
That means the wifi radio in the laptop is not on. Some laptops allow you to turn it off to conserve battery time. May want to check that.
Mar 23, 2013 | ASUS N50 N51 K50 K51 F50 X5X X5DC X5D A52...
How to connect an asus transformer to a phillips picopix 2055 projector ?
you cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
Feb 28, 2013 | ASUS Tablets & eReaders
My asus laptop doesnt want to connect to my wifi. It said to press the eeset button but i cant find it.
again u hav to instal the driver cd which is having wifi driver, and automatically ur wifi connection will display, plz make sure ur F2 key turned on for wifi..and add the passwrd nd enojy :)
Dec 05, 2012 | Computers & Internet
I cannot see available wireless connections on my asus UL50V laptop
Wifi cant be swtiched on at the laptop. Can be the only issue - if it is, suspect radio receiver fault.
Dec 19, 2010 | ASUS m6n Notebook
Cant connect to wifo internet and just got laptop
I really do not understand your problem or question.
If you can not connect to the internet, or you do not have access to your networking thru your wifi connections, you will have to bwe more detailed for anyone to provide help.
Nov 27, 2009 | ASUS P5S800-VM Motherboard
Why cant i connect my dlink
Forget the D-Link drivers!!! I suffered with this same DWL-G630 issue for two years, trying different settings, reloading drivers, all with no solution. My card kept dropping it's connection, or wouldn't connect at all until I removed then replaced the card. Finally, I read on another forum this card uses the same chipset as an ASUS card, and to try the ASUS drivers. I downloaded and manually installed the drivers from here:
ftp://ftp.asus.com.tw/pub/ASUS/lan/wifi-g/wifi-g.zip
Unzip it, but DON'T run the setup.exe file, because it will try to install the ASUS program. If you open the unzipped folder you will find another folder called "Drivers". Just use your Network Settings (from your Control Panels) to manually update the driver of your DLink card, and navigate to the Drivers folder just mentioned. Reboot -- you'll probably have to reconnect to your access point/router one last time, but that's it! It's good as gold after that.
I was used to losing connections 5-8 times PER DAY (I'm 15 feet from the router!) and now I've been connected non-stop for two weeks and counting!!
Mar 20, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
How is the wifi set up for the asus motherboard?
your moblile and pc motherboard are just like a terminal. they cant connect each other directly.
but there is software to access a mobile through wireless. this will set your motherboard as server and your mobile as client.seach in google
Mar 18, 2008 | Intel Motherboard
ASUS B1M - Ultra-bright Wireless Led Projector Logo
47 people viewed this question
Top ASUS Video Cameras Experts
Are you an ASUS Video Camera Expert? Answer questions, earn points and help others
