Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
FISHER AND PAYKEL REFRIDGERATOR RF610A ERROR CODE F2
ERROR CODE F2
fanny
  • 146 Answers
SOURCE: Fisher & Paykel Dishwasher
If the machine has stopped and still has water in it, the drain pump is jammed. The pump is situated under the machine on the right hand side and can be accessed if you tilt the machine back against a wall. Try turning the motor fan by hand. Sometimes it will clear any foreign matter caught in the pump. If still jammed, remove pump by switching the machine off at the wall and pulling out the plug. Remove the wiring harness from the pump and turn it clockwise while releasing the white plastic clip which holds it in place and keeps it from turning on its own.
Posted on Nov 03, 2007
ngfam1
  • 639 Answers
SOURCE: fisher and paykel intuitive error code 37
Dear chopper667,
ngfam1 here for you!
I am happy to be of assistance!
Try unplugging the washer and then rebooting it after 3 minutes!
If this fails,
here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Posted on Aug 26, 2008
SOURCE: Fisher and Paykel Intuitive has
I had the same problem, code 43 is an out of balance switch problem, i found mine was just sticky, if you pull it out (under the electronic control unit, under the top panel) you may be able to find out if its stuck or if it needs a new one, you could possibly find one from another model. hope this helps
Posted on Dec 26, 2008
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
How do i take the bins out of the freezer? fisher and paykell product no 20717 model E372B.
Text, manuals and videos.
[PDF]Installation instructions and User guide - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../838360b-nz-au-gb-ie-eu-ae-hk-sg-refrigerator-active...
Never freeze liquids in glass containers. Liquid expands during freezing, which may cause the container to explode. ?. ?. Never freeze carbonated drinks. They may explode. ?. ?. Do not consume food if it is too cold. Food removed from the freezer compartment may be cold enough to cause damage when brought into ...
[PDF]Refrigerator & Freezer - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../821187-nz-au-gb-ie-pac-refrigerator-freezer-guide.p... Food removed from the freezer compartment may be cold ... E372B. E381T. E402B. E411T. E415H. E406B. E413T. E440T. E442B. E521T. E522B. A inside height. 853 1255 1635 1255 1635 1475 1735 1465 1635 1735 1635 ..... The humidity lid seals the bins to provide a humid microclimate to extend storage times of fruits.
Page 41 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Permanently fixed bins and trays (Freezer drawer models only). The freezer bins and trays in this model are permanently fixed. They cannot be removed from the. freezer compartment. To clean simply wipe with a soft, damp cloth. On vacation/holiday.. Turn the ice maker to OFF on the internal control panel (refer to page ...
Page 25 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Remove all frozen food and wrap it in several layers of paper. Place food in the refrigerator. compartment or a cool environment e.g. insulated picnic bin. Switch the power off at the wall. The temperature control can remain at its normal setting. Remove the freezer baskets or shelves for ease of cleaning. Whilst defrosting ...
Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A ...
https://manualsdump.com/en/manuals/fisher-and-paykel-e442b...e372b/.../41 Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins ...
Refrigerators - Removing & Replacing The Drawer on Vimeo
? 2:35
https://vimeo.com > Fisher & Paykel Technical > Videos
Jun 29, 2012 - Uploaded by Fisher & Paykel Technical
This video shows the proper method for removing and replacing the drawer on Fisher & Paykel ...
Ice Storage Bin - Fisher & Paykel ActiveSmart E372B Installation ...
https://www.manualslib.com > ... > Installation instructions and user manual
Fisher & Paykel ActiveSmart E372B Manual Online: Ice Storage Bin. All models When going on vacation/holiday we recommend cleaning your ice bin and discarding...
[PDF]Fisher & Paykel RF522ADX5 519L French Door ... - Winning Appliances
https://www.winningappliances.com.au/.../Fisher---Paykel-RF522ADX5-519L-French... Note: non-Ice & Water models do not have an external water dispenser. Refrigerator French door and freezer drawer. Refrigerator door and freezer door .... 9. Installation instructions. Product dimensions (mm). E372B. RF372B. E402B. RF402B. E442B. RF442B. E522B. RF522B. A overall height of flat door product. 1620.
fisher & paykel e522b manual
https://sway.com/JxXqIwtViE8mDVwl Products 1 - 20 of 23 - Shop with confidence on eBay! Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, ...
fisher and paykell E372B remove freezer bins Google Search
Feb 18, 2018 | Fisher Refrigerators
On the 2nd draw will start washing but not even a minute flashes the F2 error and stop washing, what this means?
Hi Francesca, The link below is a short youtube video on how to simply fix f2 on your fisher and paykel dishwasher.......CHEERS..
https://www.youtube.com/watch?v=qP_X9iG0f-g
Mar 29, 2016 | Fisher and Paykel Dishwashers
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Jan 02, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
My dishwasher is not working and has an error code of F2. How can I fix this problem?
F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
Good luck.
May 05, 2011 | Fisher and Paykel Dishwashers
I have a f1 come up and a f2 on my dishwasher what is it
f1 = Flood Code
This means that the dishwasher most likely has a leak
There is a float switch in the bottom of the machine and when water gets down there it trips the code
F2 = Roter not moving
you can remove the basket and spray arm and pull the roter out and make sure its clean and give it a try.
Jan 21, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
173 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
